Changing brake position switch
Old Apr 15, 2023 | 07:48 PM
Cali6's Avatar
Cali6
1st Gear
Default Changing brake position switch
I'm having an issue with the brake position sensor making loud clicking noise, When I step on the brakes, the front parking lights dim,other wise no codes appear.also if I change sensor do I need a scan tool to recalibrecalibrate?
Old Apr 15, 2023 | 09:49 PM
C6VetteLover's Avatar
C6VetteLover
Never did one on a C6 but I've done them in other cars and it's just plug and play, they are generally just a normally open momentarily closed switch activated by the brake pedal.
Old Apr 15, 2023 | 11:24 PM
87SAM's Avatar
87SAM
If memory serves me, it seems like a sensor relearn procedure will have to be completed post replacement. It is more than an off/on switch.
Old Apr 16, 2023 | 01:40 AM
Rocketmanwpb's Avatar
Rocketmanwpb
I recently had to replace the brake master cylinder and the vacuum booster. The break light switch has an arm that moves with the brake pedal to activate the brake lights. Sounds like you need to replace it. It is a simple binary switch that does not require any relearning procedure.
To Changing brake position switch
