What is the best leather protector
Old May 16, 2023 | 08:48 AM
gpruitt54's Avatar
gpruitt54
Default What is the best leather protector
Just replaced cashmere leather seat covers. What is the best product to prevent blue Jean color from staining the seats over time? Also, I don't what that super shinny look.
Old May 16, 2023 | 09:56 AM
LCZ06's Avatar
LCZ06
I really like chemical guys leather care products.
https://www.chemicalguys.com/leather...PI_109_16.html
Your question is like asking what your favorite soda is. You’ll get a million different answers.
Old May 16, 2023 | 09:58 AM
BadAV's Avatar
BadAV
If you replaced with OEM leather it has a urethane coating on top of the leather, so leather conditioners basically don't soak into the leather. Just periodically use a gentle leather cleaner to remove the blue. Or you can use one of the combo cleaner/conditioner products if it makes you feel better.
I worked tier one OEM seating supply quality engineering/management for over 10 years so I am very familiar with seat material testing and qualification requirements.
Old May 16, 2023 | 10:40 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
https://adamspolishes.com/search?type=product&q=leather
Adams has some great leather care products.
Old May 16, 2023 | 10:43 AM
sramzzz's Avatar
sramzzz
I use Mothers products in mine. As to cleaning use warm soap and water.
Old May 16, 2023 | 11:15 AM
81VETTOM's Avatar
81VETTOM
I use their Pristine Clean it works great and has for many many years, on my leather and vinyl. Cleans great and smell like leather and not some perfumy stuff and put it on with your hands. The Rejuvenator is for great for real leather hides and not leatherette type finishes. Pristine Clean will soften the seats and makes cleaning a lot easier for lighter seat colors too.
https://leatherique1.com/
Old May 16, 2023 | 01:23 PM
vetteish's Avatar
vetteish
Took me a long time to accept this advice!! I will say i still use a cleaner combo for the nice smell
Old May 16, 2023 | 09:38 PM
Arehman11's Avatar
Arehman11
Gtechniq tri-clean followed by gtechniq leather guard. This is going to protect you from having dye transfer.
Old May 16, 2023 | 10:37 PM
skybolt31's Avatar
skybolt31
I have read this before that OEM leather has a coating, so should we be using leather conditioner or cleaner or should we be using any sort of vinyl treatment like 303?
thanks
Old May 16, 2023 | 11:34 PM
gpruitt54's Avatar
gpruitt54
thanks
Old May 17, 2023 | 07:11 AM
JABCAT's Avatar
JABCAT
thanks
Damp microfiber cloth. Easiest way to spot real leather vs almost all automotive "leather" is to put a couple drop of water on it. If it soaks in, real leather, if it sits on top plastic coated. Corvette seats are the plastic coated variety.
Old May 17, 2023 | 07:20 AM
BadAV's Avatar
BadAV
Leather conditioners won't hurt anything but the only place they will actually absorb into the leather is if the urethane coating has worn off or cracked. If you keep loose dirt and debris off the seats so they aren't "sanding" the leather when you are getting in/out and moving around on the seat while driving, the urethane coating tends to hold up well for many years.
I used a leather cleaner product to periodically clean blue jean transfer from my wife's tan Enclave seat bolster. Most of my leather interiors have been dark color so blue jean transfer doesn't show. I personally rarely use conditioner products on my seats or dash. I use a vacuum with crevice tool to remove loose dirt, then wipe seats and dash down with damp microfiber towels that have a little car wash detergent on them, followed by a dry towel to remove any moisture. If the seats start looking dry or the urethane cracked to expose the leather I like the creme type leather conditioners. Let the seat get hot in the sun, then rub it on by hand. A little goes a long way; I feel doing it directly with your hand makes it easy to make sure you get conditioner everywhere, and especially rubbed into those spots you feel need attention. Let it "soak" in for a couple of hours after application, then wipe everything down with a clean towel to remove any remaining conditioner. This is just my approach. I am certainly not claiming this to be the best or only way to do it; it is just what has worked well for me.
The wife's Charger is 10 years old now, has never needed any conditioner treatment, and the seats still look great. I owned a 2002 Avalanche for 14 years and only treated those seats a couple of times. They also still looked great; the GMT800 leather was bad about wearing, and especially for developing cracks/creases.
Old May 17, 2023 | 08:35 AM
Esoteric Detail's Avatar
Esoteric Detail
Supporting Vendor
Good morning!
You can use a product like Gyeon LeatherShield to help prevent occurrences of blue jean transfer and other staining and make cleanup easier when the occasional mishap happens. It won't make the surface shiny or stiff and will retain the original look and feel of the surface.
How to protect white interiors from staining!
Please don't hesitate to reach out at any time with any product or detailing-related questions! You can reach our Product Support line at 614.855.2573 or via e-mail at sales@esotericcarcare.com.
__________________
________________________________________ __________________________
ESOTERIC Fine Auto Finishing - America's Premier Corvette Detailer
Detailing . Paint Protection Film . Protective Coatings . Car Care Product Sales . Training
HRE Wheels . Forgeline Wheels . BBS Wheels . Akrapovic Exhaust . Fabspeed Exhaust . KW Suspension
9801 Karmar Ct. New Albany, Ohio 43054
(614) 855-6855
Contact@esotericdetail.com
EsotericDetail.com
EsotericCarCare.com
ESOTERIC on YouTube
Old May 17, 2023 | 09:14 AM
vetteish's Avatar
vetteish
Originally Posted by Esoteric Detail
Good morning!
https://youtu.be/GVou4icwcsw
I have learned so much from esoteric. I didn’t know they were a supporting vendor. I have called several times and they always help me with my issues. I’m subscribed to their YouTube too
Old May 17, 2023 | 05:07 PM
Esoteric Detail
Supporting Vendor
Thank you for the the kind words, we're glad you find our content helpful! Never hesitate to contact us with any questions as our Product Support staff exists specifically to help you!
Be sure to sign up for our e-mail newsletter at the bottom of our Home Page at ESOTERIC Products...it will keep you abreast of any current/upcoming promotions (Hint: The last few weeks of May are going to be a very busy time here!)
Enjoy!
Old May 17, 2023 | 07:26 PM
C6 Snowboarder's Avatar
C6 Snowboarder
I dont do much except when ladies get to ride I ask them to sit on a towel.
Old May 18, 2023 | 08:38 AM
MacB's Avatar
MacB
I've had excellent results with Zaino leather conditioner on my cashmere leather seats.
To What is the best leather protector
