Z06 brakes
you can use the Wilwood caliper kit and keep stock rotors. improves braking quite a bit
Installed Carbotech 1521s on my Z06: Carbotech brake pads coupon code z28 - CorvetteForum - Chevrolet Corvette Forum Discussion
Pricey, yes; however, dusting's been all but eliminated w/ excellent stopping/wear.
Very pleased.
Used OEM GM discs all aroud, inexpensive & always available.
Very pleased.
Supporting Vendor
St. Jude Donor '11,'13
Depends how aggressive you want. Do you care about noise and dust? I will list 2 compounds below the 1521 is quiet and stops fine for daily use the AX6 is aggressive bite with dust and some noise.
CARBOTECH™ 1521™
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound’s excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
CARBOTECH™ AX6™
The AX6™ is specifically engineered for Autocross applications. A high torque brake compound delivering reliable and consistent performance over a very wide operating temperature range of 50°F to 1000°F + (10°C to 537°C+). The advanced compound matrix provides an excellent initial bite, high coefficient of friction at lower temperatures along with very progressive brake modulation and release characteristics. Many drivers use the AX6™ for street driving as well, even though Carbotech™ doesn’t recommend street driving with AX6™ due to possible elevated levels of dust and noise. AX6™ is NOT recommended as a race compound in most applications.
CARBOTECH™ 1521™
CARBOTECH™ AX6™
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Landru (06-06-2023)
