Tpms ???
Old Jul 20, 2023 | 02:34 PM
h2oskiman's Avatar
h2oskiman
Default Tpms ???
I am going to be replacing the tires on the car .The TPMS have been on the car since new 15 years .They still work fine but the prudent thing to do is to replace them .
Not sure which way to aftermarket or oem . Any advice would be appreciated >
Old Jul 20, 2023 | 03:22 PM
jrose7004's Avatar
jrose7004
I always get whatever ones the tire store sells and they always work fine.
Old Jul 20, 2023 | 04:14 PM
sramzzz's Avatar
sramzzz
Go to rockauto.com and see if they have the schrader sensors to fit your car. This is who made the oem ones to begin with. I purchased mine there 3 years ago and programmed them with the tool without issue. Cost then was less than $100 bucks delivered.
Old Jul 20, 2023 | 09:39 PM
Chukman's Avatar
Chukman
Rockauto is a good source. I got my last set of AC Delco's thru Amazon.
Old Jul 21, 2023 | 05:28 PM
Rick369's Avatar
Rick369
I agree Rock Auto and Schrader TPMS sensors for your year Corvette. I recently bought Schrader TPMS sensors from Rock Auto for my 2011 Grand Sport. They were $21.97 each plus shipping. Shipped the next day after I placed the order.
Old Jul 21, 2023 | 06:17 PM
Corvette_Ed's Avatar
Corvette_Ed
I use the ones provided by Discount Tire when I get my tires changed. Their warranty is good for 7 years, which is about 2 tire changes for me. I've had some go out and Discount Tire replaced them absolutely free. No charge to me for re-mounting and balancing the tires.
Old Jul 21, 2023 | 06:58 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Speaking from my C5 experience, I would go GM Genuine if you can.
Old Jul 21, 2023 | 08:09 PM
Rick369's Avatar
Rick369
You do know that GM Genuine are made by Schrader.
Old Jul 22, 2023 | 07:20 AM
cadyshac's Avatar
cadyshac
I just put schrader on mine, works great.
Old Jul 22, 2023 | 09:59 AM
cyclesailor955's Avatar
cyclesailor955
Be sure the TPMs you purchase are PreProgrammed.
The PreProgrammed units will simplify the recognizing procedure with the Vette.
Old Jul 22, 2023 | 07:41 PM
C6Ninja's Avatar
C6Ninja
Cruising
+1 for Rock auto. I usually just buy whatever one is most popular that's in stock. I went with these ones and have no complaints.
https://www.rockauto.com/en/moreinfo...pt=12036&jsn=1
Old Jul 22, 2023 | 08:27 PM
HBsurfer's Avatar
HBsurfer
I use whatever the tire shop sells when I buy new tires. I have done this for 3 sets of tires on my C6 as well as every other car I have owned that had tpms. I have not had a single problem.
Old Jul 26, 2023 | 11:32 AM
cmonkey713's Avatar
cmonkey713
Replace the sensors. The batteries usually only last about ten to twelve years best case.
Old Jul 28, 2023 | 11:35 AM
Corvette_Ed
Originally Posted by ZRCLONE
Mine were put in when I put my new wheels and tires on, maybe 4-5 years. Started having issues and the front right stopped working. Bought the tool on Amazon and did the procedure front right is out "obviously the battery". They were all new and GM. So instead of risking my wheels and tires, GM Sensors at $65 each=$260 plus the cost of install and re-balance $?, I bought all four on Amazon for $64 and $15 of PVC. I think anyone with a car like this should be prudent enough to check tire pressures and not need the over complicated warning system. When I do new tires will probably do new but now all is good.
OR....you just have the tire shop provide the sensors, and if one goes out the mounting and balancing is on their dime, not yours.
Old Jul 28, 2023 | 11:42 AM
MissileDoc's Avatar
MissileDoc
I bought the OEM ones from Rock Auto and they have been trouble free for several years.
Or you could roll the dice and use the units from the tire store.
Old Jul 28, 2023 | 12:17 PM
skybolt31's Avatar
skybolt31
I was going to go with Schrader units for all the reasons stated but Amazon has the GM ones on sale for $50 so I went with them.
Amazon Amazon
To Tpms ???
