Key fob!!! Help
Old Aug 12, 2023 | 07:42 PM
shawn07vette's Avatar
shawn07vette
Cruising
Default Key fob!!! Help
I can not get my 2007 atomic orange convertible vette to go into
acc mode
learn mode.
Will not start
will not lock
or unlock doors
will not work the windows
or the radio.
Or convertible top
display says no key fobs detected.can someone with a tech 2 machine in the phx-mesa area come and help me please.my cell is 480-228-9599
Old Aug 12, 2023 | 07:52 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Moved to the C6 section.
Old Aug 12, 2023 | 08:39 PM
FatsWaller's Avatar
FatsWaller
And you tried to see if the fob will work in the glovebox slot?
Old Aug 12, 2023 | 09:37 PM
kkupec02's Avatar
kkupec02
welcome
Old Aug 12, 2023 | 10:17 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Did you try your 2nd fob? Did you check the battery in the fob? Battery should read about 3.2 volts.
Old Aug 12, 2023 | 10:34 PM
Vette_DD's Avatar
Vette_DD
And voltage of the fob battery doesn't matter when you use the fob in the glovebox slot. It uses the car battery when you do that.
To Key fob!!! Help
