Throttle blipping?
Old Sep 6, 2023 | 09:40 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
I bought this, 3 days after I got my car and discovered I couldn't heel'n'toe otherwise....which I've been doing for over 50yrs now and is one of the pleasures of owning a manual.
Having coached several people on this over my life, including GF, and later wifey, its actually a tad easier to sync up on track, where its done at higher rpm and with hard braking makes deceleration rate faster.
An annoying thing on many modern cars is the throttle hang which keeps the revs up for emissions...
https://www.eliteengineeringusa.com/...num-gas-pedal/
Old Sep 6, 2023 | 07:05 PM
Dano523's Avatar
Dano523
Originally Posted by 80atez
So I'm the only one who brakes with my heel to blip with my toe on my c6z06?
BMW I use big toe for brake 5th toe for throttle blip. Vette is too car apart to do this for me.
Just you ,since I use the palm of my right foot for breaking since have more braking control that way, and just slip my heal over to touch off the gas pedal to blip instead.
Really, just comes down to how far the pedals are adjusted apart, and in the case of pedals that will not adjust, then wider left base pedal on both the gas pedal, and on either brake left or clutch pedal right side, so don't have to go a country mile for left foot brake check for pad kick out on the last of the drive a well.
As for why no Vet every came with adjustable pedals, just goes to the depths of how far they value engineered the cars to keep production cost down.
Old Sep 6, 2023 | 07:35 PM
KennyPowers's Avatar
KennyPowers
You're going to be better off if you over rev your rev match, so start comfortably in the over rev zone and as you get better you'll end up spot on.. my .02
