Steering Column Cover Removal
Old Sep 12, 2023 | 02:57 PM
Corvette_Ed's Avatar
Corvette_Ed
Default Steering Column Cover Removal
Does anyone have any instructions on how to remove the cover from the steering wheel column so the multi-function switch can be replaced? Temps are starting to go down out here in Phoenix so I'd like to start fixing some things that I've been putting off because of the heat. TIA!!
Old Sep 12, 2023 | 07:10 PM
JABCAT's Avatar
JABCAT
The top and bottom halves just snap together, iirc. You should be able to separate it with a thin trim removal tool.
Old Sep 12, 2023 | 08:16 PM
DrKrieger's Avatar
DrKrieger
did mine last week.......
Old Sep 12, 2023 | 10:03 PM
Corvette_Ed
Where were the connection points? I just want to make sure I don't break anything.
Old Sep 13, 2023 | 02:38 PM
JABCAT's Avatar
JABCAT
Pretty sure right around the stalk openings on both sides. Tried to find a pic of when I covered them with leather, but couldn't find it.
Remove steering column shroud
To Steering Column Cover Removal
