EBCM Rebuild
Old Oct 17, 2023 | 09:05 PM
Brett D's Avatar
Brett D
Default EBCM Rebuild
I have a EBCM that is in need of being rebuilt on my 2005 C6. I have seen a few businesses that advertise rebuilding and returning the module….ABS Fixer being one of them.
Has anyone on here used this type of service, and if so who did you use? Thanks!
Old Oct 18, 2023 | 08:49 AM
Corvette_Ed's Avatar
Corvette_Ed
This isn't discussed much here at all. The C5 forum would be a good place to get some leads on reputable rebuilding companies as it is much more prevalent on that model.
Old Oct 18, 2023 | 09:07 AM
Brett D's Avatar
Brett D
Thanks! I’m a newer Corvette owner, so learning as I go. I’ve been driving it with the fault, but would feel more comfortable having traction control active. I’ll check the C5 forum for info.
Old Oct 18, 2023 | 08:20 PM
4SUMERZ's Avatar
4SUMERZ
How do you know that it' the ECBM causing the fault? Do you have the DTC code?
Here are a few site that were advertised on the C6 Forums awhile back.
https://www.upfix.com/product/chevro...epair-service/
https://www.absfixer.com/catalog/index.php/cPath/21
https://repairlaboratory.com/repair-service-2005-2008-corvette-c6-cadillac-xlr-abs-ebcm-control-module-corvette-c6/
Old Oct 18, 2023 | 08:29 PM
Brett D's Avatar
Brett D
I don’t have the code, it was diagnosed by a former GM tech that works for the shop I have my work done at. Thanks- these are the two I also found doing research.
To EBCM Rebuild
