Hi 😃👍
my hatch button by the licenceplate on my c6 doesnt open the trunk…my fobs are working fine, and then button by the sterringwheel works to.
i took the button out and got a meter on it and i works fine…..took a wire and short the plug but nothing happens.
anybody got an idea where to go from here🤔
4SUMERZ
close
- Member SinceSep 2009
- LocationEastern
Liked:2,437 Times in 1,727 Posts
did you take the switch apart. Most times if everything else opens the hatch but that button, it's dirt in there making it stick.
https://www.corvetteforum.com/forums...-pictures.html
4SUMERZ
close
- LocationEastern
Quote:
Ok, so possibly, it is at the latch assembly unit itself. A connector possibly? I've attached the color schematic of the hatch assembly wiring. It may help you troubleshoot.Originally Posted by Jesper Bongo Dahl
I removed the switch and tested it with a voltmeter…it makes connection.. works like i should…
