New Code
Old Nov 8, 2023 | 08:14 PM
BF Alexander's Avatar
BF Alexander
Default New Code
I just installed a new battery in my 08 coupe. Everything has gone smoothly with one mystery code
appearing on the DIC : A HD AAOLTIVER 2 . Can anybody clue me in?
Old Nov 9, 2023 | 08:21 AM
C6ToGo's Avatar
C6ToGo
Was it blurry? You might put your glasses on.
No way that is a code or warning. Your owner manual lists all the possible choices.
Hopefully not Serial Bus/COM problem gibberish.
Old Nov 9, 2023 | 09:28 AM
Kenny94945's Avatar
Kenny94945
Yeah, seems like a gibberish.
Perhaps it is referring to Driver 2?
Hopefully this is not computer module related.
Noting you replaced the battery and then this message appeared.
Try pressing your door memory buttons for driver one or ensure you have fob 1 (your main fob) with you.
Don't forget your window indexing
Let us know what you find.
Old Nov 9, 2023 | 09:40 AM
VetteVinnie's Avatar
VetteVinnie
If it's on the DIC, is it possible that it's a programmed user name for the Driver?
Old Nov 9, 2023 | 11:13 AM
BF Alexander
Confusing, but thanks
Old Nov 9, 2023 | 11:14 AM
BF Alexander
Not blurry, just weird ,
Old Nov 9, 2023 | 12:05 PM
VetteVinnie
From the owner's manual:
Personalize Name: This option allows you to type in a name or greeting that will appear on the DIC display whenever the corresponding keyless access transmitter (1 or 2) is used or one of the memory buttons (1 or 2) located on the driver’s door is pressed.
Press the OPTION button until PERSONALIZE NAME appears on the display, then press the RESET button to scroll through the following modes:
• YES
• NO (default)
If you choose YES, you can type in a name that will appear on the DIC display.
To program a name, use the following procedure:
1. Enter the PERSONAL OPTIONS menu and select the driver number (1 or 2) that you would like to program by following the instructions listed previously under “Entering the Personal Options Menu”.
2. Press the OPTION button until the PERSONALIZE NAME option appears on the display.
3. Select YES under PERSONALIZE NAME by pressing the RESET button.
4. Press the OPTION button and a cursor will display where you can insert a letter.
5. Press the OPTION button again until the letter you want is displayed. To scroll through the letters faster and without a beeping noise, keep the OPTIONS button depressed. There is a complete alphabet and a blank space available.
6. Then press the RESET button to select the letter of your choice and proceed on to the next space to the right.
If you make a mistake and would like to clear or replace a letter, perform the following steps:
6.1. Press the RESET button to reach the letter you would like to change.
6.2. Press the OPTION button to scroll through the letter choices.
6.3. Press the RESET button to select the letter and proceed on to the next space to the right.
7. Repeat Steps 5 and 6 until the name or greeting you want is complete. After the name or greeting is complete, keep pressing the RESET button until the display turns blank and exits out of this option. You can program up to 20 characters.
If you choose NO, this option will turn off.
If a customized name or greeting is not programmed, the DIC display will show Driver 1 or Driver 2 to correspond with either the number on the back of the keyless access transmitter (1 or 2) that is being used or to the memory button (1 or 2) that is pressed. PERSONALIZE NAME is the last option available to program in the PERSONAL OPTIONS menu. Pressing the OPTION button after this setting will exit you from the PERSONAL OPTIONS menu. The last item you were in prior to entering PERSONAL OPTIONS will then display on the DIC.
To New Code
