Winterizing a C6
Old Nov 26, 2023 | 05:56 PM
rapiano@aol.com's Avatar
rapiano@aol.com
2nd Gear
Default Winterizing a C6
I am a recent owner of a 2009 Corvette coupe and getting ready to store it in a garage for the winter months in the Northeast. Any suggestions on which type/brand of trickle charger to use on the battery (located in the front engine compartment) along with the best way to connect it? Any other suggestions for the winter storage?
Old Nov 26, 2023 | 06:12 PM
oldcanuck's Avatar
oldcanuck
Maybe try a search on this forum. Tons of threads and suggestions. No need for another.
Old Nov 26, 2023 | 06:50 PM
lobstah24's Avatar
lobstah24
https://www.walmart.com/ip/Battery-T...rger/782270305
Old Nov 26, 2023 | 06:59 PM
4SUMERZ's Avatar
4SUMERZ
Hi and welcome. I would suggest a Deltran Battery Tender Plus for the Battery Tender. I have had mine since 2010, use it from Nov-Apr each winter 24-7, and from May-Oct, use it daily to recharge my golf cart 12V battery. It does not owe me anything. I actually purchased a new one last year, just in case, but it's still in the box. After 13 years of pretty much year round usage, it's still going strong.
The other items
Fill up gas tank, put Stabil in the tank.
Pump tires to 35-40 psi
Leave hood ajar in case battery goes bad.
Put some Bounce sheets in the car
Put the cover over the car-uncover in the Spring.
Old Nov 26, 2023 | 07:57 PM
FatsWaller's Avatar
FatsWaller
As above, but add a bottle of Techron as well, and add both before you fill the tanks so that it mixes. Best to do this with the fuel gauge below 1/4 if possible so that the additives flow and mix into both tanks, and then run the engine at least 5 minutes so the Stabil and Techron flow through the entire fuel system. So, arrive at the gas station with the car up to operating temperature if possible, add, fill up, and drive home.
Old Nov 26, 2023 | 08:19 PM
rapiano@aol.com
2nd Gear
Thank you!
Old Nov 26, 2023 | 08:26 PM
CorvetteFan1953's Avatar
CorvetteFan1953
2024 C6 of the Year Winner - Unmodified
If your situation allows, and this is what I personally do, drive it if it’s above 40 and dry and no salt on the ground. I am in the NYC area and don’t store the car. It’s in a heated garage that sits around 65 in the winter and 68 in the summer on a battery tender. Sunoco 94 octane. When I suspect it will sit a couple weeks, I’ll pump the tires up as well.
Otherwise, Stabil for sure. I personally have not used any.
Old Nov 27, 2023 | 09:55 AM
PAPAYOYO's Avatar
PAPAYOYO
Tanks?
Old Nov 27, 2023 | 10:01 AM
TorchRedFred's Avatar
TorchRedFred
If everyone did a search, there would never be any new posts. Everything there is to discuss has probably already been discussed at some point.
Old Nov 27, 2023 | 10:35 AM
FatsWaller's Avatar
FatsWaller
Originally Posted by PAPAYOYO
Tanks?
You’re welcome!
There are 2 fuel tanks - left and right, joined by a crossover hose.
If you search for it, there's a pretty good write up on the forum of how the system operates and pumps fuel from one tank to the other.
Old Nov 27, 2023 | 10:45 AM
PAPAYOYO's Avatar
PAPAYOYO
You've welcome!
Learned something today. Thanks
Old Nov 27, 2023 | 11:07 AM
gilbybarr's Avatar
gilbybarr
One last thing....don't get into the habit of starting it, letting it run for a while, then shutting it off. Unless you are going to take it out and drive it and let everything get all warmed up and cozy, best to leave it alone for the duration of the winter till spring. We are lucky here in Tennessee in that we have pretty mild winters generally so no big deal to "prep for winter."
Old Nov 27, 2023 | 07:50 PM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
Plus change the oil before storage. I rather the car sit in clean oil than dirty oil.
​​​​​​​CTEK is a popular battery tender.
Old Nov 27, 2023 | 08:08 PM
LCZ06's Avatar
LCZ06
Welcome to the site and congrats on the purchase. You will get a million different answers on winter storage but the two most important things to do are using a trickle charger ( Battery Tender Plus 12 Volt) and Stabil in a full gas tank. As others have suggested do a google search linking corvette forums (the search on here sucks imop).
Old Nov 27, 2023 | 09:47 PM
old motorhead's Avatar
old motorhead
Send it down to me and I'll drive the snot out of it all winter. No charge for the service. It'll be good to go when you pick it up in the spring.
Old Nov 28, 2023 | 05:28 PM
oldcanuck's Avatar
oldcanuck
Ya ok. That was my cranky old man retired practical accountant side jumping on a newbie first post. Apologies to OP.
Old Nov 28, 2023 | 06:01 PM
Vette_DD's Avatar
Vette_DD
Just quit driving one of my C6s for a day or two. Left it under the open air carport.
To Winterizing a C6
Old Nov 28, 2023 | 06:25 PM
AllenB's Avatar
AllenB
Veteran: Marine Corps
Originally Posted by torchredfred
if everyone did a search, there would never be any new posts. Everything there is to discuss has probably already been discussed at some point.
exactly!
Old Nov 29, 2023 | 07:52 AM
Wayne88's Avatar
Wayne88
Originally Posted by 4SUMERZ
The other items
I'm just curious, if these Bounce sheets are the ones you put in the clothes dryer to keep clothes from wrinkling, what do they do for a car?
Old Nov 29, 2023 | 08:42 AM
FatsWaller's Avatar
FatsWaller
Just remembered something else that I do. It’s been suggested that the entry point for mice into the cabin air intake system is the space around the wiper arm posts through the cowl. So I stuff a few drier sheets around the posts to block the space. Take care to leave some of the sheet protruding so you can easily remove them. As to what the sheets do, it’s alleged that mice don’t like the smell, so the sheets discourage them. And of course keep your car from wrinkling. Mine always emerges from the cover in the spring nice and smooth, so it must be true,
