TPMS re-learn
Old Nov 28, 2023 | 06:07 PM
corvette_maniac's Avatar
corvette_maniac
Default TPMS re-learn
The C6 showed 0 PSI at the L rear today. It had 30PSI. I did the re-learn with the tool and it does relearn the first 3 but not the one that was showing 0 PSI. I'm guessing battery. Can someone tell me where to find those batteries?
Thanks.
Old Nov 28, 2023 | 06:13 PM
PMPerformance's Avatar
PMPerformance
You replace the tpms sensor when the batteries get low.
Pretty sure these are all sealed units
4SUMERZ's Avatar
4SUMERZ
Thanks.
Replacing the battery is near impossible, so you will need to buy new sensors. Make sure you buy the GM or Schrader sensors. Some of the genetic brands won't always connect.
Old Nov 28, 2023 | 06:53 PM
C6ToGo's Avatar
C6ToGo
I think the DIC should display PSI=XX for dead sensor....not PSI=0. So might investigate further.
Sensors are sealed with non-replaceable batteries.
Old Nov 28, 2023 | 09:43 PM
corvette_maniac
Definitely said 0.
I ordered the batteries. I'll get into it.
Old Nov 28, 2023 | 09:47 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I know when my car showed XXX they battery was dead and replaced with OEM, those units are sealed, and if get to replace the battery please tell all of us, I know I'm interested.
Old Nov 28, 2023 | 10:14 PM
PMPerformance
Definitely said 0.
oem sensors can be had for like $20 a piece.
why not just order new sensors?
Old Nov 29, 2023 | 01:12 AM
G l e n's Avatar
G l e n
For 20 bucks I would order new. The aggravation factor isnt worth it. Imho
To TPMS re-learn
