E Brake button removal
Old Jan 27, 2024 | 01:13 PM
RizVet's Avatar
RizVet
Default E Brake button removal
I've read several posts here that to replace the button (upgrading to a CF dipped version) slide the e brake leather boot down, remove screw holding handle in place, then pull fairly hard to remove handle with button. Question - Not sure if a later year C6 is different than early years with regards to the button, as I see that the button on my 2012 has a small opening that seems to be a "release" of some sort. Will yanking it break this? Is their a way to remove the button without pulling handle off? Any help is appreciated, thx.
Old Jan 27, 2024 | 01:57 PM
sramzzz's Avatar
sramzzz
Yep that’s it. Pull on the handle and the button will pop out when it lets go. Takes a bit of force.
Old Jan 27, 2024 | 02:20 PM
RizVet's Avatar
RizVet
So have to remove handle to release button? No other way?
Old Jan 27, 2024 | 02:27 PM
racerx3317's Avatar
racerx3317
No sir, there’s no other way that I know of.
sramzzz's Avatar
sramzzz
I don’t think there is enough surface area on the button to grab and pull. Not a big deal to pull the boot down, remove a screw, and give it good tug.
To E Brake button removal
