Idle problem
Old May 3, 2024 | 11:16 AM
belsy's Avatar
belsy
Default Idle problem
2005 6 speed with headers and an open air box otherwise stock. Recently my idle does not decrease as quickly as it should rev it up to quick rev to 2000 or so and slowly drops back down to 8 or 900 rather than dropping quickly otherwise running fine but this can be annoying in traffic! Any thoughts on what this could be it just came out of nowhere no changes no codes, any thoughts or suggestions would be appreciated
Old May 3, 2024 | 05:02 PM
jamieo's Avatar
jamieo
I would probably start by cleaning the MAF sensor and throttle body.Will cost less than $10 and only a few minutes of your time.It can't hurt to try.
Old May 5, 2024 | 01:36 PM
dave4881's Avatar
dave4881
Cruising
Get it on Amazon...
Old May 5, 2024 | 02:55 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I’d check your throttle body for deposits on the bore where the throttle plate closes…also check that the plate moves smoothly as someone pushes on and then releases the go pedal with ignition in run.
Old May 7, 2024 | 11:51 PM
DrKrieger's Avatar
DrKrieger
I have the exact same problem.......cleaned the MAF sensor, and TB, even replaced the MAF sensor AND the TB.....still does the same thing. SC'd LS7, ported and polished heads, Belanger Custom Tri-Y Headers........I just "put up with it" however it is annoying. I took it to the dyno AGAIN and the tuner has no idea why it's happening.
Any suggestions would be appreciated.....
Old May 8, 2024 | 07:18 AM
PMPerformance's Avatar
PMPerformance
Typically in other cars I have experienced this, it is IACV problems, specifically the decay rate.
Not sure if these cars even have an iacv, but if so, I’d check that out and clean it out. They can get gummed up over the years.
Old May 8, 2024 | 08:03 AM
C5 Diag's Avatar
C5 Diag
No Idle Air Control Valve.
Old May 8, 2024 | 10:22 AM
wjnjr's Avatar
wjnjr
If the problem has been there since you built the car, ask if he checked the idle related tables like base airflow, coast down spark, adaptive idle, etc. They can all effect a throttle hang if they are off. It actually takes more time and effort to get driveability right than WOT when tuning a custom build like yours. That's where the tuner's skill and experience come in.
If he gives you a blank look, find another "tooner" .
According to the OP, his problem occurred suddenly. The idle hang in this case will most likely be caused by a mechanical problem like a sticking throttle butterfly or a vacuum leak, because tunes don't just spontaneously change.
Good luck to both you guys, let us know what the fix is when you find it.
Old May 8, 2024 | 08:03 PM
jeffs64's Avatar
jeffs64
Tuner
Old Jun 12, 2024 | 02:06 PM
belsy's Avatar
belsy
Thanks to all replies!!!!!!!!
I have pulled the entire air intake off & cleaned the throttle body then pulled neg bat cable, yet no change???? It simply will not drop back to IDLE after shifts or just after revs ??? ANY thoughts ??
Thanks in advance....................
Old Jun 12, 2024 | 02:40 PM
wjnjr's Avatar
wjnjr
1) If the problem has existed since the car was modified, then something in the modifications caused it. Look for a vacuum leak and/or a bogus "toon".
Or,
2) If the car was running fine since the mods, and the problem just appeared, not coincident with work on the car, then suspect a sticking throttle body or a vacuum leak.
Old Jun 12, 2024 | 03:35 PM
belsy's Avatar
belsy
I will check for vacuum leak, but just for the thought....I had added a filter to my catch can which i''m not sure of the benefits?? I will let all know as I have removed the filter , pulled neg cable just in case and we will see????
Old Jun 12, 2024 | 03:58 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
This is not the Corvette ownership experience we strive for. Our team would like the opportunity to learn more about the idle on your C6 and investigate ways we can potentially assist. When you get the chance, please send us an email to socialmedia@gm.com. Be sure to include your Username and Forum name in the subject line, then provide additional details about your experience in the body of the email. We look forward to your contact.
Old Jun 12, 2024 | 10:05 PM
wjnjr's Avatar
wjnjr
If the problem started after you monkeyed around with modified the PCV system, suspect the obvious. If that filter vents to atmosphere, there's your vacuum leak. Put it all back to stock and see how it runs. For info on how to properly set up a catch can, contact Mr. Mighty Mouse.
Picture of me tuning a carburetor back in the day.
Old Jun 13, 2024 | 04:01 PM
belsy's Avatar
belsy
I have removed the vent // filter from the catch can and it is better!!! Now the idle will drop as expected..........
Thanks to all..................................... .
Old Jun 13, 2024 | 08:52 PM
wjnjr's Avatar
wjnjr
Great, glad you found the problem and it was something simple,
Seriously, to learn all about PCV systems and catch cans, go to : http://www.mightymousesolutions.com/
Mr, Mighty Mouse is very helpful whether you're a customer or not.
Just beware of our own self-appointed world's greatest tuner & PCV expert catch can ****. He usually shows up when people start talking about catch cans.
To Idle problem
