Brake Bleeding Procedure
Left rear-Right front then Right rear-Left front. CHECK !!
But,the caliper has 2 bleed screws,1 inboard,1 outboard.
Which bleed screw should I bleed First ???
Also a proper ABS pump bleed requires a Tech2 or some other system to activate the pump valves for air removal.
C6 MANUAL BRAKE BLEEDING
Install a proper box-end wrench onto the RIGHT REAR wheel hydraulic circuit bleeder valve.
Install a transparent hose over the end of the bleeder valve.
Submerge the open end of the transparent hose into a transparent container partially filled with GM approved brake fluid from a clean, sealed brake fluid container.
Have an assistant slowly depress the brake pedal fully and maintain steady pressure on the pedal.
Loosen the bleeder valve to purge air from the wheel hydraulic circuit.
Tighten the bleeder valve, then have the assistant slowly release the brake pedal.
Wait 15 seconds, then repeat steps 8-10 until all air is purged from the same wheel hydraulic circuit.
With the right rear wheel hydraulic circuit bleeder valve tightened securely, after all air has been purged from the right rear hydraulic circuit, install a proper box-end wrench onto the LEFT FRONT wheel hydraulic circuit bleeder valve.
Install a transparent hose over the end of the bleeder valve, then repeat steps 7-11.
With the left front wheel hydraulic circuit bleeder valve tightened securely, after all air has been purged from the left front hydraulic circuit, install a proper box-end wrench onto the LEFT REAR wheel hydraulic circuit bleeder valve.
With the left rear wheel hydraulic circuit bleeder valve tightened securely, after all air has been purged from the left rear hydraulic circuit, install a proper box-end wrench onto the RIGHT FRONT wheel hydraulic circuit bleeder valve.
After completing the final wheel hydraulic circuit bleeding procedure, ensure that each of the 4 wheel hydraulic circuit bleeder valves are properly tightened.
Fill the brake master cylinder reservoir to the maximum-fill level with GM approved brake fluid from a clean, sealed brake fluid container.
Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
Toys
