Window Adjustment
Old Nov 26, 2024 | 06:37 PM
visionary's Avatar
visionary
Default Window Adjustment
Hi there,
I looked through the archives for the C6 window adjustments. I found one with pics that shows the adjustors I need to deal with the height.
I need to raise the window slightly to seal and this is NOT an indexing fix. That being said, I found a thread from years ago showing the rubber seals you need to remove both front and back. I need to know which way the screws adjust the window. Does loosening (Or turning the adjustor left) raise the final height or is it the opposite? I remember to tip in on my C5 you had to turn the adjustor left (counter-clockwise) to tip in and the other way to tip out. Thanks and Happy Thanksgiving to all of my friends on this forum! Stay safe and full of food!
Mike Fesi
