Stereo recommendations
here is discussion when I first did it I used c7 logo, lol
But all fixed
https://www.corvetteforum.com/forums...ddx9907xr.html
I did not loose my Custom Boot Screen Updating Firmware, I kinda figured not , but one never knows.
I also attached a picture of the Custom Boot Screen, yes you can load picture files but that is only for Wall Paper and NOT BOOT SCREEN
AI OverviewYes, you can put a custom .bmp image on most Kenwood car screens for the boot-up/splash screen. It requires a FAT32-formatted USB drive, a .bmp image (typically
[img]data:image/gif;base64,R0lGODlhAQABAIAAAP///wAAACH5BAEAAAAALAAAAAABAAEAAAICRAEAOw==[/img]
pixels, 16-bit or 24-bit color depending on the model), and often requires initiating a "standby" menu or specific button sequence (e.g., top-left corner twice) to trigger the import.
Key Requirements & Steps:
- Image Format: The file must be a (Bitmap) format.Code:
.bmp
- Resolution: For most modern, high-resolution screens, this is 800 x 480 or 1280 x 720 pixels.
- USB Setup: Use a USB drive formatted to FAT32.
- Procedure:
- Place the file on the root of the USB drive (often namedCode:
.bmp
or placed in a specific folder, depending on the model).Code:image1.bmp
- Put the Kenwood head unit into Standby mode.
- Go to the Settings menu and look for "Display" > "Customize" or a similar menu.
- Select "User Customize" to import the image from the USB.
- Some models require a secret sequence: Putting the unit in Standby, then tapping the top left, top left, bottom left, bottom left, top left, top left to open a special menu.
- Place the
- Alternative Method: For some models, it is simply Settings -> Display -> Startup Image -> Change.
