Touching
Old Feb 2, 2025 | 03:07 PM
PAPAYOYO's Avatar
PAPAYOYO
Default Touching
Hello fellow C6ers. Question. I have a 2011 GS convertible and as the top goes does it rubs against rear glass a bit..Please Help!
Thanks!
Old Feb 2, 2025 | 03:39 PM
Jmmoore3's Avatar
Jmmoore3
Torsion straps are done. Lots of good posts on here about replacing. Most will say just pull glass forward with one finger while the waterfall is opening and closing past it.
Old Feb 2, 2025 | 03:43 PM
6 Shooter's Avatar
6 Shooter
Here is a good thread…
https://www.corvetteforum.com/forums...strap-fix.html
Old Feb 2, 2025 | 04:55 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
This solution is easy and one you should consider. It's not a problem that you need to spend a lot of time or money on fixing. Replacing the tension straps is only a temporary fix. The straps will stretch again and the problem will return.
Tom
Old Feb 3, 2025 | 06:25 AM
CorvetteCam91ZO7's Avatar
CorvetteCam91ZO7
Default In another 10 years
Tom
Not really a temporary fix. After you fix , it will be fine for many years. Same as a set of tires everything has a life expectancy.
I would consider the repair 1 - 10 a 2 on the difficult scale 10 being the hardest.
Easiest access to the strap is with the roof straight up , throw a couple of bungee around the roof holding the back glass loosely folded so you can get your hands in the side . Then accessing the strap , the top of the strap is attached with a rivet bottom is a small hex head maybe 7mm or 10mm if I remember . I just grabbed rivet head with a good pair of side cutters wiggling it out like pulling a tooth 😂 not putting close pressure to cut , being careful not to cut the head of the rivet off . Bam reinstall the new rivet and strap repeat the process on the other side.
Everything I fix takes 3 times longer than it should , me a couple of hours . A normal person 😂 an hour 👍 it’s not a hard fix
To Touching
