CD Player - No Disc Loaded Code
Old Feb 22, 2025 | 11:02 AM
NortheastZ06's Avatar
NortheastZ06
Default CD Player - No Disc Loaded Code
Went to use my CD player for the first time. The previous owner left a CD in the unit and it started to play when I turned on the head unit and selected "CD". I ejected the disc and put mine in, and I keep getting the "No disc loaded" on the screen. Any ideas?
Old Feb 22, 2025 | 11:51 AM
Corvette_Ed's Avatar
Corvette_Ed
Is it a commercially made CD, or one you burned yourself?
Old Feb 22, 2025 | 01:18 PM
NortheastZ06
commercial cd
Old Feb 22, 2025 | 01:21 PM
Corvette_Ed
Originally Posted by NortheastZ06
commercial cd
You can try a CD cleaner, but if that doesn't work, there's a good chance that it's dead.
Old Feb 22, 2025 | 01:48 PM
cadyshac's Avatar
cadyshac
I tried everything on an '05 I owned several years ago with no results, good luck.
Old Feb 22, 2025 | 02:12 PM
Dano523's Avatar
Dano523
Try another CD, or if you can burn a disc, then over burn one and see if it solves the problems.
Short of that, then may need to pull the Player apart, to clean not only the top of len, but get into the lens to clean the bottom section lens as well.
http://hyperphysics.phy-astr.gsu.edu...io/cdplay.html
Old Feb 22, 2025 | 09:12 PM
FatsWaller's Avatar
FatsWaller
Since the disc the previous owner left in the player worked, the first thing to try is to put that disc back in and see if it still works. If it does, as Dano suggested, try another disc. Maybe the one you tried isn’t compatible with vette player.
Old Feb 23, 2025 | 02:04 PM
Corvettechris86's Avatar
Corvettechris86
Is it the touchscreen nav unit? I have a base model radio for $20 I just posted in the fs section.
Old Feb 23, 2025 | 07:32 PM
NortheastZ06
Took me a while but I found this
https://www.corvetteforum.com/forums...reads-cds.html
Old Feb 23, 2025 | 11:30 PM
MannyS's Avatar
MannyS
Try these guys if you need to get the changer repaired:
https://doctordons.com/corvetteradios.htm
Old Feb 24, 2025 | 09:11 AM
NortheastZ06
Touch screen with Nav. Thanks for the offer though
Old Feb 24, 2025 | 11:36 AM
hcbph's Avatar
hcbph
Sorry but I don't know what unit came in originally in a C6 so this is just a thought. Does it have provisions for a thumb drive source? If so and you have provisions for it, burn the cd to a thumb drive and enjoy the music.
Old Feb 25, 2025 | 08:39 AM
blownbayou's Avatar
blownbayou
Did the same thing about a month ago.... Decided to try a disc in the player. It skipped audio and now it will not recognize the cd. Tried the disc cleaner and it will not recognize it. Then tried compressed air and it still will not recognize the cd.
Just left the cleaner disc in there and hope for the best. Not wanting to take the radio back out and dismantle it.
Old Feb 25, 2025 | 09:03 AM
NortheastZ06
This is what I was thinking about....the player not recognizing the cleaner disk
To CD Player - No Disc Loaded Code
