C6 Front Splitter/Valence
Old Feb 28, 2025 | 04:58 PM
C6GSRay's Avatar
C6GSRay
5th Gear
Default C6 Front Splitter/Valence
Looking to replace the lower front splitter/Valance panel on my 2012 Grand Sport Corvette. Any suggestions on a good replacement that will fit without modifications other than the OEM?
Old Feb 28, 2025 | 07:46 PM
js78's Avatar
js78
This is what I bought and installed, fits perfect
https://www.americanmuscle.com/corve...v06z06-pu.html
Old Mar 17, 2025 | 01:43 PM
C6GSRay's Avatar
C6GSRay
5th Gear
Thanks js78 Racer.
Old Mar 17, 2025 | 02:54 PM
MannyS's Avatar
MannyS
FYI. Some of the aftermarket “oem style” GS front spoilers are hard plastic or fiberglass that will be significantly damaged on the first driveway dip you enter.
Old Mar 17, 2025 | 03:37 PM
Snappahead's Avatar
Snappahead
Which is why I never replaced mine. Mine is scraped on the bottom half and it bothers me but I don't see the use of replacing it only to damage it backing out of my driveway. My C6 scrapes on everything. My C5 is fine.
Old Mar 17, 2025 | 04:58 PM
Pettrix's Avatar
Pettrix
You can get this for less than the OEM tack-on piece. The ZR1 front splitter actually creates downforce BUT if you will be doing speeds above 100mph, then you will need to get a front reinforcement piece to prevent the front bumper from being deforming due to the downforce being placed on it.
https://extremeonlinestore.com/produ...18710663594051
Old Mar 17, 2025 | 07:10 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
I have an EOS ZR1 - Z06 front splitter on mine. In between each attachment point I put 3M VHB tape and it's on there very solid with no reason to add additional bracing. I have have the opportunity to drive at about 130 MPH with no visible issues.
Old Mar 17, 2025 | 09:00 PM
Pettrix's Avatar
Pettrix
It's not the front splitter that will deform, it's the front bumper that will deform at high speeds.
Old Mar 17, 2025 | 09:15 PM
Dano523's Avatar
Dano523
The c6 ZR1 still has lift at speed, so keep that mind. Its just less than say the base car.
Hence best even Katech could do was get a few hundred lbs of down force front/back with full aerodynamics front and back with full kit at speed, while you had the Enzo getting it full weight in down force at the same speeds instead.
Old Mar 18, 2025 | 02:10 PM
Pettrix's Avatar
Pettrix
What kind of speeds are we talking about?
What year Enzo are you referring to?
Old Mar 19, 2025 | 05:57 PM
tebrules's Avatar
tebrules
saw a guy on youtube install one of these and bought one. They are only $69-89 on ebay.(cost me 75 delivered) They come in 3 pieces(plastic)You can barely see the seem(inside of air duct space) Believe it or not, it fit perfect, didn't have to drill holes at all. I figure at that price I could replace it every couple yrs and be way ahead, since i have to replace it regularly anyway Will look better when car is clean!! I know it will be blasphemy to some, but to me, the part is disposable and I don't have to fret that it is going to cost me a fortune if I drag it. Buy 2 and you can replace whichever part breaks!!
Old Mar 19, 2025 | 08:00 PM
Brickmaster's Avatar
Brickmaster
I got a nice plastic zr1 spoiler off of eBay came painted and in three of exes was only $80
Old Mar 23, 2025 | 05:23 PM
jk47's Avatar
jk47
5th Gear
Definitely read the sellers feedback. Have had Issues with sellers shipping from here in the USA but based out of China. Poor quality, missing parts, bad attitude. Basically buying a throw away piece so it’s up to you to decide whether or not buying the cheapest option is worth the hassle.
Old Mar 23, 2025 | 06:01 PM
Brickmaster
I had no issues. Finish was good. Fits. Realistically, I live in NYC, I replace these every 6 months. I can buy one for much more that really is nothing to write home about from Extreme, but this will do
Old Mar 23, 2025 | 06:07 PM
jk47's Avatar
jk47
5th Gear
Glad it worked out for you.
Old Mar 24, 2025 | 02:56 AM
AgainstTheWind's Avatar
AgainstTheWind
Went with EOS. Too notch shipping, packed extremely well. I did the hydro dipped, if I could do it over I would have gotten the carbon.
To C6 Front Splitter/Valence
