Header install
Old Apr 4, 2025 | 06:36 PM
shutout's Avatar
shutout
Default Header install
Does the Quick jack have enough clearance to install headers?
Old Apr 4, 2025 | 07:15 PM
PMPerformance's Avatar
PMPerformance
it can be done. People do them on jackstands. It won’t be the easiest job you have done though.
Old Apr 4, 2025 | 07:37 PM
mnorth04's Avatar
mnorth04
If you can fit under the car then yes. I’d suggest feeding the headers in from the top though and if you have a friend to guide them in from the bottom it should be easy.
Old Apr 4, 2025 | 07:41 PM
shutout's Avatar
shutout
Thanks! I'll be installing my headers this weekend. (Hopefully).
Old Apr 4, 2025 | 07:48 PM
mnorth04's Avatar
mnorth04
Take your time. If it’s just the headers it shouldn’t be too bad. If you’re doing the whole exhaust it can get a little frustrating to get everything to line up how you like. Take out the spark plugs before you remove/install the new headers too. Don’t wanna snap one off inside the block.
Old Apr 4, 2025 | 08:53 PM
shutout's Avatar
shutout
I'll be installing a full exhaust Connecting to a Borla Atak exhaust I installed last year.
Old Apr 5, 2025 | 07:28 AM
Spaceme1117's Avatar
Spaceme1117
You want to get as much height as possible. 24" inches or more.
And I don't think you will be able to install the headers from the top, just not enough clearance.
Definitely remove the spark plugs.
Can also help to remove the engine mount nut on the bottom of the side you are installing and then very carefully use a piece of wood on the oil pan to jack up a little bit. It will pivot the engine on the opposite engine mount and give you more clearance. Then for the other side, re-install the mount nut on the side you just installed and remove the other one. Repeat.
Old Apr 5, 2025 | 09:37 AM
mnorth04's Avatar
mnorth04
Yoy can definitely install from the top. There’s a bunch of videos on YouTube showing it and I also know from personal experience. Atleast with the speed engineering longtubes I know you can. Not sure about other manufacturers
Old Apr 6, 2025 | 10:07 AM
Whodamans's Avatar
Whodamans
If its not too late... Make sure you do them in the correct "order"
I did my SE LT headers and Xpipe i went Front - back and could not cinch up the connection to the "over axel" pipe to fit. Go back to front, Bolting the header on last might be a little awkward but it was the only way to do it. I also have a little rubbing now on those over axel pipes to the frame. Make sure you slam those connection together before you clamp everything down.
Old Apr 6, 2025 | 10:39 AM
NuToVettes's Avatar
NuToVettes
Yes. I installed Kooks 1/7/8” long tubes on my 2010 base model in my garage over the winter with my set of QuickJack 5000.
To note, spark plugs and oil dipstick were removed and new headers were feed up from underneath the car into position.
Old Apr 7, 2025 | 09:01 AM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
plenty of room - if i can do it, so can you!
Old Apr 8, 2025 | 12:01 PM
EviLS7's Avatar
EviLS7
Wish I had my quickjack when I did my headers originally. But it can be done on jack stands with a little finess.
Old Apr 8, 2025 | 12:35 PM
shutout's Avatar
shutout
That's great to hear! I didn't want to have the oh sh$t this isn't going to work halfway through the job.
To Header install
