Speaker Help.
Old Apr 22, 2025 | 04:23 PM
RYNO1976's Avatar
RYNO1976
Default Speaker Help.
Afternoon All,
I have a 13 GS with 12,000 miles on it. Bought the car a couple years ago with 8500. Soon after I got it, the passenger side door speaker blew. Vibration, crackling, blah blah.
I replaced the door speakers with FoCal set and 1500 miles later, sounds like absolute dog ****. Same speaker is blown. Anyone encounter this or have suggestions on a good stereo set up?
When I bought the car, I did upgrade to a Kenwood receiver,
TIA.
Old Apr 22, 2025 | 04:32 PM
madsonp's Avatar
madsonp
Originally Posted by RYNO1976
Afternoon All,
TIA.
More info needed. Are you running the stock amp ? What’s the Ohm rating of the Focal speakers (stock speakers are 4 Ohm if I remember correctly) ?
Old Apr 22, 2025 | 05:29 PM
RYNO1976's Avatar
RYNO1976
They are 4OHMs. Yes I have the stock amplifier.
Old Apr 22, 2025 | 07:17 PM
TorchRedFred's Avatar
TorchRedFred
Are we talking about he lower door woofer? You can buy new oem replacement speaker form RockAuto.com. That would be the simplest solution. There was a known issue with water getting into the door and on to the speaker making the cone separate from the frame. The replacements do have a newer part # but I am not sure if it permanently solved the issue or not.
Old Apr 22, 2025 | 07:21 PM
TorchRedFred
Part # 84510963 for the lower door woofer for the Bose system.
https://www.rockauto.com/en/parts/gm...3,speaker,1319
Old Apr 22, 2025 | 10:52 PM
FAUEE's Avatar
FAUEE
Afternoon All,
TIA.
If you replaced the 10" in the door with a focal 6.5" speaker, It likely sounded like **** the whole time. That's a midbass woofer crossed over very low, so 99% of 6.5s just don't play well there.
That said if you've blown 2 speakers this way, you likely have an issue beyond picking the wrong woofer. Could be water intrusion, could be you're driving the amp into distortion. Could be a combination of things.
Old Apr 22, 2025 | 11:54 PM
Corvettechris86's Avatar
Corvettechris86
I have a kenwood ddx and it will definitely pop the stock door “subs” if you crank it up too loud. I would put stock woofers back and just keep the bass setting to zero, it still absolutely thumps for stock and I have the non Bose.
Old Apr 23, 2025 | 11:38 AM
Dzv69's Avatar
Dzv69
I have a Kenwood head unit installed on my 2012 Grand Sport 3LT, every other component is factory. Vol on 18+ hurts my ears , the sound quality and power is excellent.
Old Apr 24, 2025 | 09:33 PM
Corvettechris86
Agreed, i kept getting headaches and come to find out it’s from how loud my radio goes! Anything over 16 on the kenwood volume and it will hurt my ears, seriously.
To Speaker Help.
