Electrical demon
I wouldn’t expect much from a dealer Tech to diagnose anything especially when it comes to electrical !!…find an auto electric shop in your area instead…they can diagnose any parasitic draw on any car…Corvettes aren’t special in this regard.
So here,
And the splice block that all the wires on it are pushed into it, is to the left of the Bose amp, and is the glowing white thing on the top left of below photo.
So unclip the splice block from the plastic is clipped to, turn int upside down, Douche the wires going into the splice block with electrical contact cleaner (get cleaner into the block as well), then one by one, push the wired into the block slightly deeper, then lightly tug back on them to make sure they have a good connection to the splice block connector clips of the splice block bar, and see if that solves the problem. If no, and still have parabolic draw from the after market not going into sleep mode when BCM tell it to, then after market radio adapter is either defective, or not on the most current firmware.
As for oem radio, could have been the splice block with signal from BCM to radio, or could have loose connection in the radio from header pin to control board via one of the ribbons. The fact that oem radio and aftermarket radio having same problems, points to the splice block in the first place; if not a low voltage problem between the Radio connector to BCM for power, or BCM back to engine fuse block on those connectors instead.
As from top of engine back, circled in red, but have to play the blind fumble game to feel find it, remove it, and them put it back on since its tight if you are going in with the motor still in the car.
So while checking/contact cleaning the X206 splice block (after you have check to make sure box drain line is not clogged from under car), Good idea to disconnect the car battery, so you can pull the BCM connectors to spray electrical clean them and the BCM pins as well.
Both 2 Blue lock connectors,and the center red connector with 7mm retainer bolt as well..
So here,
Agree, with a 2-3 milliamp draw there’s nothing wrong…what was the draw before ??…if there is no service information stating your max current draw it is usually the RC (Reserve Capacity) of the battery divided by 4 so a 100 minute RC is 25 milliamp…don’t know why you are chasing 2-3 ???
