Advice
Old Jul 5, 2025 | 04:06 PM
C6ls2TY's Avatar
C6ls2TY
5th Gear
Default Advice
Hi so I recently got a 2005 c6 manual ls2 corvette the car has 23k miles on it and I’m looking at building the car. This is my first ls motor I have worked with and just looking for some advice on building the motor correctly and trying to get the most bang for my buck. The car has sentimental value and I already know the ls2 is not the best motor compared to the 3 and the 7 but I still wanna build this one. so I’m just looking for some advice on quality parts and brands that I should look into or even a good build list
Old Jul 5, 2025 | 05:21 PM
Spaceme1117's Avatar
Spaceme1117
LS2 motor is an excellent engine so don't think of it of being inferior. It definitely is not.
Old Jul 5, 2025 | 06:40 PM
FAUEE's Avatar
FAUEE
LS2 motors would be legends if they came from a my other manufacturer. The fact that Chevy was like "we can make it even better" and made the LS3 is the only reason people say anything negative about the LS2.
That said, be aware that you can make way more power in that car than you can actually put down and use traction wise in these cars, narrow body especially.
Old Jul 5, 2025 | 07:14 PM
MissileDoc's Avatar
MissileDoc
Whoa! The LS2 is a great motor. My friend has one that is cammed, has different intake, and dyno tuned. I don't know exactly all of the mods he has done, but my point is, you have a very capable motor.
Old Jul 5, 2025 | 07:52 PM
sobe88's Avatar
sobe88
You can go 2 ways, power first or supporting mods first. LS2 is a great platform to work with, so don't listen to others on that one. If you are going power first the easiest and most bang for buck will be an ECS or A&A supercharger kit IMO.
Old Jul 5, 2025 | 08:05 PM
PMPerformance's Avatar
PMPerformance
LS2 is one of the GOAT’s
Basic bolt ons, cam and blower and let her eat!
Old Jul 5, 2025 | 09:45 PM
C6ls2TY's Avatar
C6ls2TY
5th Gear
do you have any solid recommendations?
Old Jul 5, 2025 | 10:27 PM
cthusker's Avatar
cthusker
I’m the original owner of an 06 coupe. Had a E-Force installed 8 years ago which cranks out almost 600 HP with only a few more engine mods The LS2 has been rock solid and trouble free even after the S/C was installed. I believe the LS2 is an excellent motor and I have zero complaints. A small difference but I prefer the LS2 chain tensioner versus the newer one in the LS3. Bottomline the LS2 is a very solid platform and capable of producing more HP than you can hook up without some serious rubber.
Old Jul 5, 2025 | 10:38 PM
C6ls2TY's Avatar
C6ls2TY
5th Gear
thats good to hear and again I’m still learning this motor so if I say anything wrong please correct me just trying to learn as much as possible with that I’m also trying to learn from people who have built them what are some good brands they trust for heads,cams,intake and a good tune
Old Jul 5, 2025 | 11:16 PM
sobe88's Avatar
sobe88
For brand preference you are going to get everyone's opinion based on who they used. You are going to need a tune for this stuff being done, my recommendation is getting with your tuner and making a game plan for parts that way, unless you are fluent with LS tuning via HPT.
Personally most of my stuff is Texas Speed parts, custom cam through TSP, their PRC heads, one of their intake manifolds, etc. but that is the direction I went as my tuner has had good luck with TSP stuff and that was his recommendation.
Old Jul 5, 2025 | 11:50 PM
C6ls2TY's Avatar
C6ls2TY
5th Gear
appreciate the help I just moved back to Michigan so I’m still trying to find a quality tuner out here
Old Jul 6, 2025 | 10:49 AM
Landru's Avatar
Landru
LS2's a fine engine w/ plentiful parts available providing a host of ways towards upgrading.
Something to consider if modding's the rearend w/ an '05.
'05's drag raced were notorious for exploding rearends under stress.
By '06 extra reinforcement braces had been added to the casting eliminating this risk.
Morale of story?
IF upgrading HP and/or HD useage w/ an '05, installing an '06+ rearend you're golden.
Old Jul 6, 2025 | 12:57 PM
cthusker's Avatar
cthusker
Morale of story?
It’s a proven fact stock 05’s do have weaker rear ends and therefore greater potential to grenade when drag racing. A manual transmission however creates a lot more stress than an automatic especially when dumping the clutch with sticky tires. Most 05’s however never experience rear end issues because they aren’t driven to racing extremes. However when you start increasing 05’s with substantially more HP and torque all bets are off. If I was adding more HP to an 05 I’d definitely consider adding a more robust rear end.
Old Jul 6, 2025 | 04:30 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have 2005 LS2 which I have Dyno and very pleased with power, kept everything stock except for Air Filter those clip broke on the box, and went with AirRaid system.
Old Jul 7, 2025 | 09:51 PM
ariZona06's Avatar
ariZona06
Sounds like a nice find with only 23K on the clock. I'd say get a good maintenance baseline as a first step. Change all fluids, belts and filters IF maintenance history is unknown. Tire date codes ok? Then while you drive the car and enjoy it for a bit "as is" watch a few of the Toys4Life vids and get an idea of what mods you may want to accomplish. Headers are a good first addition (and pretty much required to take advantage of most mods) along with a cat delete (if no emissions testing) and a good tune to really wake up the LS2 while not setting you back the enormous coin that major mods will require. https://www.corvetteforum.com/forums...-know-vid.html
Old Jul 7, 2025 | 10:40 PM
hawkgfr's Avatar
hawkgfr
As others have correctly stated the LS2 is awesome...Unlike the ls3 cars though the air intake is a restriction on the 05-07 Vettes... If I recall correctly.. so put one of those on the list....an air intake alone will make a difference especially with an exhaust and tune you couldn't pee the difference between the two engines...
I've had both and really could not tell the difference between the two on the street...
Good luck and enjoy your Corvette
To Advice
