Balancing complete kit
Old Aug 20, 2025 | 03:07 PM
Michael Zepp's Avatar
Michael Zepp
Originally Posted by bikerdkh
I set a screw jack under the rear of the engine so it wouldn't so it would not come down as I lowered the cradle (motor mounts now unbolted). Then I used the screw jack to raise the engine a couple inches. When the cradle is lowered and the engine is raised you have a nice straight shot at the balancer. That's why I set the jack there. I understand the unweighting I've had that issue before but I did this job on my 4 post lift. Just my 2 cents worth..
Your 2 cents worth is worth a lot more to me, the c6 is different in so many ways , compared to other cars. And I'm a firm believer in knowledge being the key to success. I appreciate your help with this job. And trust me to have someone who knows how to do it because they've done it, that's the best knowledge of all
Old Aug 20, 2025 | 04:03 PM
bikerdkh's Avatar
bikerdkh
Fyi, the most frustrating part of the job, for me, was removing the electric fan. There's just not a lot of room to work. After some effort, and a number of select 4 letter words, it ended up coming out (and going back in) from the bottom. You will need to make sure you have the car off the ground enough to get it out that way if it works out, for you, the same way. Good luck!
Old Aug 20, 2025 | 04:07 PM
bikerdkh's Avatar
bikerdkh
I couldn't agree more!
Old Aug 21, 2025 | 02:32 PM
oussie's Avatar
oussie
Have fun.
If you take your time its not a bad job to do.
