Diff Fluid Recommendations
Old Feb 10, 2026 | 12:57 PM
Mike Green9's Avatar
Mike Green9
Default Diff Fluid Recommendations
Hi.
I changed the diff fluid in my base C6 back in 2010 at 8,000 Miles, using GM
Dexron LS Gear Oil 75W-90, part #88862624 (#88862625 in Canada). It came out immaculate.
Now at 45,000 Miles, I will be changing it again.
I have been looking at the 'Valvoline FlexFill Full Synthetic SAE 75W-90 Gear Oil, 946-ml#028-0219-8' and wondering if this is a better choice as it is a Full Synthetic oil.
Is this a good idea, or should I stick with the GM stuff ? If I do go with the Valvoline, would there be issues as there will be some of the old oil mixing with the newer synthetic oil?
I know you can mix non-nsynthetic with synthetic engine oil, so my guess is mixing won't be an issue. Perhaps the GM oil is in fact synthetic ??
Thoughts ??
Thanks,
M
Old Feb 10, 2026 | 01:34 PM
FatsWaller's Avatar
FatsWaller
Stick with the approved GM fluid. It has the correct amount of friction modifier already added.
Old Feb 10, 2026 | 02:05 PM
jjfabs's Avatar
jjfabs
Old Feb 10, 2026 | 02:48 PM
Mike Green9
Thanks I will,
M..
Old Feb 10, 2026 | 02:51 PM
Gearhead SS's Avatar
Gearhead SS
I used Mobil 1 75W-90. In stock at just about every auto parts store.
Old Feb 11, 2026 | 12:39 PM
ringram's Avatar
ringram
I used the valvolene 75w-90 that had the modifier in it. Zero issues, seems fine.
Old Feb 11, 2026 | 03:54 PM
Pettrix's Avatar
Pettrix
GM fluid is synthetic and has proper amount of friction modification additive.
Aftermarket fluids typically don't have the additive and it must be added separately. Some forum posts of people using aftermarket fluid and having diff chatter issues.
Old Feb 11, 2026 | 07:22 PM
FAUEE's Avatar
FAUEE
There are just as many fluids with LSD additive in them now as without.
IMO, just use whatever is the right weight, and either has LSD additive, or add it yourself if it doesn't.
Old Feb 11, 2026 | 09:13 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
GM or Amsoil.
Old Feb 12, 2026 | 12:24 AM
ariZona06's Avatar
ariZona06
Changed the Diff fluid in my Dad's '07 last summer. Used Valvoline in the convenient squeeze packs. Bought an extended fill spigot which made the operation a breeze. All items purchased at O'Reilly.
Old Feb 12, 2026 | 12:27 AM
LOURDESBELLE's Avatar
LOURDESBELLE
2025 C6 of the Year Finalist - Modified
At my first gear oil change, I used RedLine ShockProof Gear oil. Next time around, I’m going to try Amsoil Severe Gear 75w90. No additives needed.
Old Feb 12, 2026 | 06:58 AM
449er's Avatar
449er
CF Community Team
I would also agree to stay with the GM fluid, that is what I did
Old Feb 12, 2026 | 08:55 AM
MissileDoc's Avatar
MissileDoc
Originally Posted by Mike Green9
Hi.
M
You answered your own question.
To Diff Fluid Recommendations
