Shifter
Old Mar 7, 2026 | 11:37 AM
JRP06's Avatar
JRP06
Default Shifter
2006 A-6 Sometimes when I turn car off like at a gas station, then get back in start it to to leave it won't come out of park. If I shut the car off and restart it will go in gear. What's going on. Any input would be greatly appreciated.
Old Mar 7, 2026 | 02:20 PM
DR-08C6Z51's Avatar
DR-08C6Z51
It's a fairly common issue. Here's a thread explaining the problem with pictures and possible solutions. Also, C&S Corvette sells a replacement harness. The microswitches are also available online. You'd have to solder them in.
https://www.corvetteforum.com/forums...use-found.html
Old Mar 8, 2026 | 07:53 AM
seijack's Avatar
seijack
Here is a good explanation of what happens. I had this issue a couple of years ago and I went with replacing the wiring harness and switches from C&S. If you try pushing the shifter forward just a little bit to depress the front micro switch the shifter solenoid will fire and release the shifter.
Old Mar 8, 2026 | 07:33 PM
Pettrix's Avatar
Pettrix
Get the C&S wiring and switch upgrade. They are way better than what OEM GM put out, and once you install the C&S ones, it should last the life of the car. The GM ones will fail.
To Shifter
