MAF sensor code
Old Apr 27, 2026 | 08:47 PM
4SUMERZ's Avatar
4SUMERZ
Default MAF sensor code
Guys,
Last summer, I started to get the occasional Left Bank rich code by using my VCX Nano scanner. I would rest, but it would occasionally come back in.
I checked the coils, the spark plugs, removed the MAF sensor to check that out as well. All looked good. my 2006 has 125K miles on it so I replaced the spark plugs and wires, and this seemed to fix the running rich bank codes. I just recently took my car from winter hibernation, and on my first long run, I recived the MAF sensor code.
I run a Vararam Snake Charmer CAI, have had it on since 2010 or so without any issues. When I claned the filter on the CAI, I sprayed WD-40 on the back side of the filter, which I had done many times prior.
Since I didnt clean the MAF last summer, I bought a can of MAF cleaner and sprayed it good, let it dry then reinstalled. So far, no more MAF sensor codes, so I'm crossing my fingers that it was the cause of the code.
Did anyone else with a Vararam have the same issue with a dirty MAF?
Old Apr 27, 2026 | 11:22 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
WD40 ???...what product does the manufacturer say to reoil with ??...you most likely over oiled the filter and it coated the MAF sensor which will set a DTC...I always clean my MAF sensor after reoiling and running the engine.
Old Apr 28, 2026 | 11:59 PM
4SUMERZ's Avatar
4SUMERZ
Thanks, I'll get some filter oil to do the filter in the future. I wasn't aware that WD 40 is not recommended as a substitute, although older Vararam literature says to use it sparingly.
Much appreciated.
No more codes for the MAF since I cleaned the sensor
To MAF sensor code
