shifter
Old Apr 29, 2026 | 04:20 PM
markKlein's Avatar
markKlein
Default shifter
Hi, my 2009 base model has developed a practice of not being able to come out of park. So far it has released eventually, but i need to have a reliable shifte. Any thoughts or knowledge on how to fix this. It seems the new units are not available.
Help and Thanks.
Old Apr 30, 2026 | 08:42 AM
C6ToGo's Avatar
C6ToGo
Surprised a 20 year CF member has not heard of this before.
CF SEARCH
Basically, brake pedal press activates a micro switch and solenoid that moves a shift lock pawl, allowing the shifter to move. This switch or solenoid fails. See posts on replacing just the switch. Or can tie back or cut off the pawl, permitting the shifter to move without requiring a brake pedal press.
Old Apr 30, 2026 | 09:25 AM
Corvette_Dez's Avatar
Corvette_Dez
New shifter harness with improved micro switches.
https://www.corvettepartscenter.com/...-free-shipping
Old Apr 30, 2026 | 09:41 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
If you purchase the wire harness, make sure you watch their video and bend the microswitch as recommended.
Old May 1, 2026 | 02:27 AM
HK770's Avatar
HK770
https://www.corvetteforum.com/forums...use-found.html
Old May 1, 2026 | 06:59 AM
449er's Avatar
449er
CF Community Team
This is a common problem with C6 cars, lots of options out there, use the search feature on this forum
Old May 1, 2026 | 07:44 AM
markKlein's Avatar
markKlein
I spent most of my time in the C4 and C5 sections.
Old May 1, 2026 | 08:50 AM
C6ToGo's Avatar
C6ToGo
See my link above. I find seaching via Goolge yields better results than from within the forum. To limit to CF, include "Site:corvetteforum.com" in your search.
Old May 1, 2026 | 09:08 AM
surburban99's Avatar
surburban99
I had the same issue that started over a year ago with my 2008 with 38,000 miles. It would not occasionally shift out of park until I turned the vehicle off and started it again. Then it started getting worse. After I researched this on the Corvette Forum I went to my local Chevrolet dealer and told them what was going on. The Service Writer said this has become more and more of an issue with the auto tranny C6. He told me it will eventually get worse and you will not be able to shift out of park.
Luckily, they have a Corvette mechanic on staff, and they have repaired a number of these using the harness made by C&S Corvettes.
The dealer ordered the harness and installed it, and I haven't had any issues since. The Service Writer told me he doesn't understand why GM hasn't issued a TSB or recall based on the number repairs they have been doing on the C6.
You should get this fixed, otherwise you could get stranded and require a tow. Hope this gets worked out for you!
Old May 3, 2026 | 11:22 AM
Black'95's Avatar
Black'95
Help and Thanks.
Here is how I solved my problem after researching how to get at it on how to videos:
https://www.corvetteforum.com/forums...post1606799231
Old May 4, 2026 | 07:35 PM
twhanks's Avatar
twhanks
I installed the C & S kit myself and it worked great.
Old May 4, 2026 | 08:01 PM
Corvette_Dez
LOVE IT!! Great job!
Old May 5, 2026 | 06:46 AM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I did the exact same as Black 95. No worries now.
Old May 5, 2026 | 07:51 AM
markKlein's Avatar
markKlein
Thanks everybody.
To shifter
