C6 lighting issues
Old May 2, 2026 | 09:31 AM
sophcoop127's Avatar
sophcoop127
3rd Gear
Default C6 lighting issues
Hi,
I recently replaced the battery on my 2006 base coupe. I have found now that I have no tail lights, no fog lights, no parking lamps, no gear shifter indicator lights, no DIC button lights and the DRL on the Morimoto lights do not work. Headlights, turn signals and brake lights function properly. I have checked multiple fuses with no luck.
Any suggestions?
Old May 2, 2026 | 09:39 AM
1Hotrodz's Avatar
1Hotrodz
Try disconnecting the battery and re-connecting after waiting two minutes. This should reset the electrical systems. And just the battery Neg. cable has to be disconnected.
Old May 2, 2026 | 11:34 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Originally Posted by sophcoop127
Hi,
Any suggestions?
Most of the lighting circuits go through the BCM...yes, try disconnecting the battery terminals for about 5 minutes and then touch both ends of the battery terminals together (a cap discharge)...see if that works.
Old May 2, 2026 | 11:55 AM
cadbob's Avatar
cadbob
That actually works C5 Diag? I learn something new every time, always thought is was ole wise tale rumor. It’s good to know.TY
Old May 2, 2026 | 11:58 AM
C5 Diag's Avatar
C5 Diag
Old May 2, 2026 | 02:27 PM
sophcoop127
3rd Gear
i tried but no sucess
Old May 2, 2026 | 02:33 PM
sophcoop127
3rd Gear
are you referring to touching the two cables together?
Old May 2, 2026 | 02:47 PM
C5 Diag's Avatar
C5 Diag
Yes...a "cap discharge".
To C6 lighting issues
