C5/C6 side by side
Old Dec 23, 2003 | 10:50 PM
The Director's Avatar
The Director
Default Re: C5/C6 side by side (bkuper)
Ahhhh...I thought I would like the C5 better. Now I KNOW it. :cheers:
Old Dec 23, 2003 | 11:19 PM
Hoosier Red's Avatar
Hoosier Red
Default Re: C5/C6 side by side (ScottH)
I really do think the C5 profile looks more coherent. Sure, the C6 appears more "now," but there are a few things that just don't look quite right to me in profile. The first is the upper cove line being longer than the lower. Perhaps I'm just too used to the C5. The part of the front fender just aft and above the wheel appears a little too beefy. Finally, I thought a smaller butt would be better, but I would have scooped a little beef off that front fender and added to the rear.....it looks to high from the ground. The improvements I see are the concave rear horizontal surface and the slightly shorter front overhang. I can't believe they didn't consult me before the final design was approved! :crazy:
Old Dec 23, 2003 | 11:22 PM
ScottH's Avatar
ScottH
Soemthing I whipped up in Photoshop...
I hope you're not claiming my work as yours, Scott (just checking).
Absolutely not! I used your C6 (A little better than my attempt at removing the crease from in this thread: http://forums.corvetteforum.com/zerothread?id=715623) and added the C5 on the top. Thanks for providing the base :)
Old Dec 24, 2003 | 12:08 AM
bkuper's Avatar
bkuper
:thumbs:
Old Dec 24, 2003 | 12:11 AM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
All the pirate stuff aside, I'm going to Detroit in January to see C6 in person.
I'll form my opinion then, and only then.
Until then........... :leaving:
Michael
Old Dec 24, 2003 | 12:41 AM
RichieRich's Avatar
RichieRich
Default Re: C5/C6 side by side (WellAdjusted)
Also notice how the roofline in front looks to "wrap" over the windshield more, ending about midway point of the rearview mirror. C5's roofline starts a little further back it seems. Gives C6 a little more aggressive scowl.
I've griped about the C6 design, but the side profile really looks great. Not sure yet which I like "better" though. Hope I like it when I see it in person.
Can one of you choppers put those C6 rims on the C5 and maybe lower it a bit too? Just curious how much of a difference the wheels make in the overall "modernness comparison" of these two.
[Modified by RichieRich, 9:44 PM 12/23/2003]
Old Dec 24, 2003 | 12:47 AM
Registered's Avatar
Registered
The car on the bottom (C4.5?) is nice, but that really modern looking one on top (C5) looks cool.
Old Dec 24, 2003 | 12:56 AM
rhino821's Avatar
rhino821
Default Re: C5/C6 side by side (Registered)
:cool: Thanks for the pics. :thumbs:
Old Dec 24, 2003 | 01:19 AM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
Default Re: C5/C6 side by side (rhino821)
can somebody chop those c6 wheels on the c5 :D
please :cheers:
Old Dec 24, 2003 | 01:36 AM
Yano's Avatar
Yano
Yeah give props to the MASTER!!!! :hurray:
Old Dec 24, 2003 | 01:40 AM
LouieM's Avatar
LouieM
Thanks a bunch! :cheers:
The C6 definitely is a more emotional design -- what the car truly needs. And a more "emotional" motor too!
Old Dec 24, 2003 | 02:35 AM
gx624's Avatar
gx624
Combination and reworking of BKuper's and ScottH's "collaboration." ;)
With added perspective by GX624
NOTE: This is not scientific. I shrank the C6 so that the door lengths were a match. The overall length ratio between the two is closer in this pic.
Another thing worth mentioning is that the C6 mirrors are NOT C5 mirrors.
[Modified by gx624, 11:47 PM 12/23/2003]
Old Dec 24, 2003 | 02:40 AM
  #33
74_LS-4's Avatar
74_LS-4
Default Re: C5/C6 side by side (LouieM)
Old Dec 24, 2003 | 04:05 AM
  #34
Tiger Shark's Avatar
Tiger Shark
Interesting. Thanks for the side-by-side.
From the same side-view, the C5 looks sleeker and sexier than the C6.
Old Dec 24, 2003 | 05:31 AM
  #35
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: C5/C6 side by side (Tiger Shark)
I like the shorter rear window on the C6
Old Dec 24, 2003 | 07:15 AM
  #36
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: C5/C6 side by side (SWCDuke)
The taller height and less steep windshield also give the perception of a slightly airier cockpit.
I overlapped the two last night and found two things:
-Both windshields are canted back at the same angle. In other words, same rake.
-The C6 windshield is shorter. Or, rather, the base of it appears to start at a higher elevation.
Old Dec 24, 2003 | 01:12 PM
  #37
rwd's Avatar
rwd
Though Cd is reported to be down ten points (a "point" is .001, and these numbers are likely rounded down), frontal area could be a bit greater, so overall Cd times frontal area may be a wash.
Whether all the c/d numbers were obtained identically and from 'stock' cars (or scale models thereof) with all the details and warts is unknown, and all wind tunnels, even properly-calibrated ones vary somewhat.
The c/d difference could be inconsequential- as little as the .002 between hypothetical figures of .284 and .286. As you say, it's totally meaningless without frontal area information and, although it's unlikely, the drag could even be marginally worse.
As for the comparison pics, they're great, but I wouldn't read too much into them since those are GM pics. They're heavily retouched and either or both may have been altered to make the car appear longer or minimize perceived problem areas. That happens all the time. Different focal length lenses and different camera heights also render relative sizes, shapes and positions slightly differently even if the intent is to portray reality.
To C5/C6 side by side
Old Dec 24, 2003 | 01:20 PM
  #38
RiceEatingZR1's Avatar
RiceEatingZR1
Default Re: C5/C6 side by side (chadwick)
Man those fenders are awesome! :thumbs:
:iagree: :thumbs:
Old Dec 26, 2003 | 01:09 AM
  #39
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Default Re: C5/C6 side by side (RiceEatingZR1)
The C6 wins for me in every angle but the front, but that I'm withholding judgement till I see in person, cause it hasn't gotten a fair shake.
Old Dec 26, 2003 | 01:31 AM
  #40
veXati0n's Avatar
veXati0n
Default Re: C5/C6 side by side (Sniper168gr)
ScotH - Nice job! Is it my imagination or does the cab for the C6 look higher? :confused:
it's your imagination. Compare the sidemirrors and the C6 looks lower.
