C5/C6 side by side
Old Dec 23, 2003 | 07:51 PM
ScottH's Avatar
ScottH
Default C5/C6 side by side
Soemthing I whipped up in Photoshop. Interesting to see how the side profile has evolved:
Old Dec 23, 2003 | 07:54 PM
Sniper168gr's Avatar
Sniper168gr
Default Re: C5/C6 side by side (ScottH)
ScotH - Nice job! Is it my imagination or does the cab for the C6 look higher? :confused:
Butta's Avatar
Butta
Nice!!! Thanks. :cheers:
Old Dec 23, 2003 | 08:02 PM
AFVETTE's Avatar
AFVETTE
Using the mirror's as a guide it sure looks like the C5's windshield flows further back than the C6.
Tom
mike1952's Avatar
mike1952
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
:D great job! thanks :yesnod:
Old Dec 23, 2003 | 08:04 PM
chadwick's Avatar
chadwick
Man those fenders are awesome! :thumbs:
Old Dec 23, 2003 | 08:13 PM
rwd's Avatar
rwd
Default Re: C5/C6 side by side (Sniper168gr)
Overall height is 49.1" versus 47.7 for an '04 coupe.
chadwick's Avatar
chadwick
You can really see how they changed the car from this perspective. Look how much more room there is in the passenger compartment. The rear and front overhangs are much less, and the wheelbase is slightly longer. All as they told us. I'm still very surprised at how curvy and large they fenders are from the side! :thumbs:
Old Dec 23, 2003 | 08:17 PM
adamsocb's Avatar
adamsocb
The C6 is supposed to be about 5" shorter. The comparison above has them both the same length. By making the C6 longer than it is compared to the C5 it will look taller as well. Here they are with the C6 shortened 5":
According to the Autoworld article, the C6 is about 1.5 inches taller, but then they stated the length was 105.7."
Old Dec 23, 2003 | 08:43 PM
SWCDuke's Avatar
SWCDuke
Default Re: C5/C6 side by side (adamsocb)
Here's some summary data to go with the photos.
.......................................C 5...............C6
Body/Chassis:
O/A length........................179.6".... ......174.6"
Wheelbase........................104.5". .........105.7"
Curb weight, approx lbs.....3250............3245
Engine:
Bore..................................3. 90"...........4.00"
Stroke...............................3.6 2"...........3.62"
CID...................................34 6..............365
Max HP.........................350@5600..... .400@6000
Max torque, lb-ft............375@4400......400@4400
Redline.............................6200 .............6500
C6 is the SHORTEST Corvette ever built- 0.5" shorter than C2, 5" shorter than C5 - but has the longest wheelbase - 1.2" longer than C5.
Prior reports of a a less steeply raked windshield on C6 are born out by the photos. The windshield frame/dash structure is likely different than C5 as is the windshield. Seventy percent of the total parts count is new; 30 percent carryover.
Duke
[Modified by SWCDuke, 5:53 PM 12/23/2003]
Old Dec 23, 2003 | 09:07 PM
GDP's Avatar
GDP
Anyone notice how much taller the roof is? Not the height of the car, that's already been mentioned, but the roof panel seems taller and more round.
BTW, why would they make the car 1.5" taller and try to increase aerodynamics at the same time? That doesn't make any sense to me.
Old Dec 23, 2003 | 09:22 PM
ivan111's Avatar
ivan111
Default Re: C5/C6 side by side (chadwick)
C6 looks awesome those fenders are simply incredible...... :thumbs:
Old Dec 23, 2003 | 09:29 PM
SWCDuke's Avatar
SWCDuke
Default Re: C5/C6 side by side (GDP)
Taller height means more headroom. Tall drivers can feel a little cramped in C5. The taller height and less steep windshield also give the perception of a slightly airier cockpit.
Though Cd is reported to be down ten points (a "point" is .001, and these numbers are likely rounded down), frontal area could be a bit greater, so overall Cd times frontal area may be a wash.
Nowithstanding the above, with 400 HP and optimum gearing top speed should be about 180 MPH, but this is the point were GM is getting the jitters as is Goodyear. Z06 was intentionally geared a little short so its top speed is rev limited.
Duke
[Modified by SWCDuke, 6:30 PM 12/23/2003]
Old Dec 23, 2003 | 09:45 PM
Z-Rated's Avatar
Z-Rated
Default Re: C5/C6 side by side (rwd)
WOW !!!! What a Great comparison !
It does seem odd that the roof would be higher when one can see that the side glass is shorter (height). Have to wait and see the official specs.
Very nice job !! :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
Old Dec 23, 2003 | 10:13 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
Thanks! That's my new wallpaper. :D I have a 50th Anniversary Red and will be getting Daytona Orange. :thumbs: :thumbs: :party:
Old Dec 23, 2003 | 10:17 PM
C6-XTSY's Avatar
C6-XTSY
Default Re: C5/C6 side by side (SWCDuke)
Don't forget about the extra room needed if you're on the track and wearing a helmet.
Old Dec 23, 2003 | 10:24 PM
2fast2strong's Avatar
2fast2strong
ScottH, can you do a true size comparison? The C5 is longer than the C6 but in the photos both look to be the same length.
To C5/C6 side by side
Old Dec 23, 2003 | 10:28 PM
Curveit's Avatar
Curveit
Nice work guys. This really shows me the new body. I like the fenders, kinda C-3. I'm like it the more I see it. I wish I could afford one.
:chevy
Old Dec 23, 2003 | 10:29 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Looks good to me :thumbs:
Old Dec 23, 2003 | 10:45 PM
bkuper's Avatar
bkuper
Soemthing I whipped up in Photoshop...
I hope you're not claiming my work as yours, Scott (just checking).
