Lets talk keyless ignition.
Old Jan 3, 2004 | 01:58 PM
Dsob15's Avatar
Dsob15
Default Re: Lets talk keyless ignition. (drs)
"I've gone and tried to turn the car on when it was already on, and it doesn't grind the alternator"
I bet it doesn't even grind the Starter either! ? :D
Yep, I caught that one too, but was gonna "take the high road". Besides, I figured someone else would take the shot... :lol:
:iagree: Thanks for straightening that out. :thumbs:
Old Jan 3, 2004 | 02:52 PM
LongTimer's Avatar
LongTimer
Default Re: Lets talk keyless ignition. (Dsob15)
I guess we don't have any XLR people to explain it to us, so here's my guess:
The switch is a spring loaded toggle. Press in the green circle at the top and the engine starts. Remove your finger. As on the MB, once started, the top of the switch is disabled. To turn the engine off, press the bottom of the toggle. If the engine is off and you want the ACC on, press the bottom of the toggle. If the fob is not present, only the turn the engine off function would work.
Old Jan 3, 2004 | 02:59 PM
Dsob15's Avatar
Dsob15
Default Re: Lets talk keyless ignition. (LongTimer)
:iagree: Because depending on what mode the car is in when you push the bottom of the toggle, that will determine what happens. You don't just push bottom left and somethin happens, or bottom right. Which is what somebody said in another post. :thumbs:
Old Jan 3, 2004 | 03:57 PM
got2bblu's Avatar
got2bblu
If I remember correctly, the XLR requires you to have your foot on the brake at the same time you push the start button. This could be a safety feature to prevent small children from starting the car.
Old Jan 3, 2004 | 06:13 PM
CeeFive's Avatar
CeeFive
Default Re: Lets talk keyless ignition. (got2bblu)
I think a hand crank through that front grill would be really retro...
Old Jan 3, 2004 | 06:30 PM
007's Avatar
007
Cruise-In II Veteran
Yeah, but what happens if you throw the key fob out the window while driving--that should be interesting.
..Actually, I assume the car would keep running but what if you are car-jacked, maybe you do want the car to "die" if the key fob is no longer around (but car was already running).
Old Jan 3, 2004 | 06:39 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Default Re: Lets talk keyless ignition. (SBSB)
Looks like thats one solution to the collumn lock problem. :yesnod:
I think a big red button would have been cooler
[Robin voice]Atomic batteries to charge. Turbines to speed.[/Robin voice]
