Driver's door panel button function?
Old Apr 9, 2004 | 03:13 AM
KISSfn's Avatar
KISSfn
Default Driver's door panel button function?
The button in between the #1 and #2 memory buttons on the driver's door panel (which I thought was for the power convertible top, is not for that function.) Does anyone know what it is for? None of the "Product Specialists Trained in Detroit" at the Houston Auto Show had a clue! They would not allow me to look for myself! I was not allowed inside the secure perimeter (after getting busted as soon as I put a leg over the rail!) People were crawling all over other cars! (Not just the cheap cars) I know it's not for the mirrors, windows, door locks, hatch, fuel door or door latch. Both the Coupe and Vert had it. What's left?
Old Apr 9, 2004 | 08:09 AM
AT T 2D's Avatar
AT T 2D
Default Re: Driver's door panel button function? (KISSfn)
Could it be a "set" button for the memory positions? My Acura and Lexus are like that.
Old Apr 9, 2004 | 08:45 AM
Silverfinn's Avatar
Silverfinn
The "Set" button is the most likely answer. I have a Set button in my Lexus. The way it works is: You adjust the seat to your possition, you press the Set button and holding it pressed while pressing possition #1 or possition #2 as the case may be.
Old Apr 9, 2004 | 11:27 AM
KISSfn's Avatar
KISSfn
Default Re: Driver's door panel button function? (AT T 2D)
My '01 Vette Coupe has the two memory buttons but no set button, you just press and hold the memory button.
Old Apr 15, 2004 | 03:00 AM
myfirstvetc6's Avatar
myfirstvetc6
ITs to open the doors electronically
Old Apr 15, 2004 | 09:04 AM
Hurricane's Avatar
Hurricane
Moderator
Cruise-In I Veteran
Default Re: Driver's door panel button function? (myfirstvetc6)
Passenger seat ejection button...
Old Apr 15, 2004 | 09:06 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
No, that's the button on the door handle.
To Driver's door panel button function?
