LP Bracket - Different Answer
Old Apr 28, 2004 | 06:54 AM
gx624's Avatar
gx624
Default LP Bracket - Different Answer
Most license plate holders cover a 1/2" margin on the top and sides of the plate
and up to 3/4" on the bottom. So, top + bottom = 1.25" of the plate is covered
by the holder.
I don't know the dimensions of the Smoothie that people use on their C5's,
but it looks to be approx. 3/4" all the way around. That would make
only 4.5" height of the plate's 6" visible.
If the Smoothie is legal (the plate is considered readable)
at only 4.5" uncovered height...
... then, if one wanted to, one could cut a slot in the lower lip of the mouth
at the front of the grill, and inset the plate. A pointed acrylic cover could
deflect air around the plate.
Might not be "the" answer (blocking airflow),
but I think it's a legitimate answer, and more
appealing than GM's design. Note: This plate
is to scale.
Click on pic for larger version.
[Modified by gx624, 3:55 AM 4/28/2004]
Old Apr 28, 2004 | 07:53 AM
Matt Gruber's Avatar
Matt Gruber
Default Re: LP Bracket - Different Answer (gx624)
sure thats good. won't block much airflow.that slot is huge.
i would mount it under the spoiler with a cable to keep it retracted except when and if i get pulled over, then i pull cable(under the dash) and flip the plate down.
Old Apr 28, 2004 | 08:34 AM
mikeivan's Avatar
mikeivan
"Might not be "the" answer (blocking airflow),
is to scale."
PERFECTO
Old Apr 28, 2004 | 09:34 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
That looks good. Can someone go to the Museum with a plate to see what attachment points are in the grill area?
Old Apr 28, 2004 | 10:42 AM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: LP Bracket - Different Answer (Another Yellow)
It looks like it has buck teeth.
Old Apr 28, 2004 | 10:51 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Definitely better than Chevy's application.
Old Apr 28, 2004 | 01:18 PM
xilr8n's Avatar
xilr8n
Another 'zip tie mod'
Old Apr 28, 2004 | 05:14 PM
AP's Avatar
AP
I like that better than GM's solution ...
Old Apr 28, 2004 | 05:41 PM
AP's Avatar
AP
Another place to stick the plate is where a lot of Camaro owners put their plates ...
Old Apr 28, 2004 | 06:26 PM
Beaz's Avatar
Beaz
Default Re: LP Bracket - Different Answer (AP)
Thats great idea but im thinking that to keep the C6's looks intact the best way to go will be a hide-away license plate
Good Work though
Old Apr 28, 2004 | 07:16 PM
AP's Avatar
AP
Default Re: LP Bracket - Different Answer (Beaz)
Good Work though
Hideaway Plate? but where could it be hidden is the question ...
Old Apr 29, 2004 | 06:04 PM
BHP's Avatar
BHP
Might as well slap a label on the nose.
Old Apr 29, 2004 | 06:20 PM
50MileSmile's Avatar
50MileSmile
Unfortunately, there are two reasons this won't work in some states: 1) Part of the plate is hidden and 2) It's lower that the minimum ground-to-plate measurement.
Old Apr 29, 2004 | 07:19 PM
gx624's Avatar
gx624
Default Re: LP Bracket - Different Answer (50MileSmile)
hmmm... you may be right, but...
1) Same as the Smoothie.
2) Roughly 1" lower than the C5 plate.
Old Apr 29, 2004 | 07:31 PM
Troy Roberts's Avatar
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In II Veteran
Cruise In III Veteran
Cruise In IV Veteran
Cruise In V Veteran
Cruise In VII Veteran
St. Jude Donor '03-'04-'05-'06-'07
That's definitely a step in the right direction.
As to it being a bit too low for some states - I wouldn't worry that much about it. You're not likely to be pulled over for a plate that is one inch too low. Not as likely as for not having a front plate at all anyway.
Old Apr 30, 2004 | 12:55 AM
SisqSam's Avatar
SisqSam
AP's idea would work in California. There is no minimum front plate height requirement like there is for the rear, only a 60 inch maximum height requirement. See CVC Section 5201. Putting it behind the windshield could violate other provisions (CVC 5201(f)), and the overall provision that the plate must be clearly visible and legible (cop says he or she can't see through the windsield reflection). Assuming it won't scrape the ground, AP's solution is the one I am aiming for to avoid blocking airflow. Hopefully, the aftermarket will step in so I don't have to fabricate my own bracket.
[Modified by SisqSam, 5:56 AM 4/30/2004]
Old Apr 30, 2004 | 08:19 AM
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In V Veteran
How about setting it up so that it's folded down unless you push a button or pull a release that lets it pop up somehow? If you start to get pulled over you just pop it up. "What do you mean officer? I have a front plate."
To LP Bracket - Different Answer
Old Apr 30, 2004 | 09:58 AM
scorp508's Avatar
scorp508
Default Re: LP Bracket - Different Answer (Matt Gruber)
Sure only about 33%.
Old Apr 30, 2004 | 02:54 PM
corvette1271's Avatar
corvette1271
Default Re: LP Bracket - Different Answer (barkingowl)
....looks like a squirrel....yes glad that i have my 13k 94 c4 now.......it looks
quite nice thank you very much with a plate on front.....
Old Apr 30, 2004 | 10:07 PM
gx624's Avatar
gx624
Default Re: LP Bracket - Different Answer (scorp508)
Well, with a little more investigating and approximating, the inside-the-air-scoop placement is out of the question -- it would block 50%+ of the airflow. Placement on the lower lip would kill aerodynamics and block significant bottom breathing. Placement on the lower right (passenger's side) would kill airflow to the brakes and screw up downforce.
Here's a look at it from a different perspective. (Measurements are based on pixels and are approximate.)
Of course, and clearly, engine cooling and aerodynamics were/are much more important to the designers/engineers than a front license plate bracket, and so, unfortunately, for those who live in front plate states, there are really only two choices:
1. Rivet the brick on the C6's front fascia (and demand that they come up with something a little more pleasing to the eye).
2. Pay the fine(s) for no front plate.
Right now, it's all or nothing.
Come on, Chevy! Fix that Fugly Thing!
