C6/Z06 performance comparison...
Old May 14, 2004 | 12:44 AM
08msmZ06's Avatar
08msmZ06
Default Base C6/'02 - '04 Z06 performance comparison...
First of all, I'm talking about the base C6 models here...not the C6 Z06.
We've all seen the "guesstimates." I think it will fall a little short of the
'02 - '04 Z06 performance numbers: 0 - 60 and 1/4 mile, in particular. I'm
basing this on the performance numbers of the '90 - '95 ZR-1, and how the
base C5 models never exceeded that car's performance. I think at best the
base C6s will fall just short of matching the current Z06. I'm not trying to
start WWIII, and I'm not biased because of my '04 Z . It's just my
expectation/opinion (FWIW) based on what's occurred with GM in the past.
[Modified by 04msmZ06, 3:10 AM 5/14/2004]
Old May 14, 2004 | 12:53 AM
Ryan Bell's Avatar
Ryan Bell
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: C6/Z06 performance comparison... (04msmZ06)
C6 coupe will be slightly slower. That's my guess.
Old May 14, 2004 | 01:26 AM
wildman378's Avatar
wildman378
Default Re: C6/Z06 performance comparison... (Ryan Bell)
I think it will take a z06..why? it's lighter and just has 5hp less.
and if you compare the z06 now to a c6 z06 well the new ones will have 500hp! no comparsion the c6 z06 I read will do 11.7 easy
[Modified by wildman378, 6:27 AM 5/14/2004]
Old May 14, 2004 | 02:19 AM
Yogivette's Avatar
Yogivette
Default Re: C6/Z06 performance comparison... (wildman378)
We've been told it will be a lil slower.
Old May 14, 2004 | 03:59 AM
08msmZ06's Avatar
08msmZ06
...if you compare the z06 now to a c6 z06 well the new ones will have 500hp! no comparsion the c6 z06 I read will do 11.7 easy
Not what I asked; the C6 Z06 is going to blow us all away I'm sure. However,
I think it also will fall a little short...of 500 HP anyway. The '02 -'04 Z06,
however, will remain slightly quicker than a base C6. Watch and you'll see...
[Modified by 04msmZ06, 3:02 AM 5/14/2004]
Old May 14, 2004 | 08:31 AM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
This is from the Birthday Bash
Old May 14, 2004 | 08:44 AM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Default Re: C6/Z06 performance comparison... (Another Yellow)
I remember that slide he talked about them being very close and in some areas exceeding the Z06.. I wish that I had the one that showed the performance at the rpm levels comparision.. the C6 was ahead of the current Z06 for the most part....I may look for that one....
Old May 14, 2004 | 09:41 AM
wildman378's Avatar
wildman378
Default Re: C6/Z06 performance comparison... (TRAYC6)
"Not what I asked; the C6 Z06 is going to blow us all away I'm sure. However,
however, will remain slightly quicker than a base C6. Watch and you'll see..."
I DID answer your question just added my thoughts on the c6 z06 as well.
I told you I think the c6 will beat the current z06 why? it's lighter and has jues 5hp less.
Old May 14, 2004 | 09:44 AM
Bwright's Avatar
Bwright
Default Re: Base C6/'02 - '04 Z06 performance comparison... (04msmZ06)
The C6 will meet (base coupe) or exceed (Z51) the performance of the outgoing C5 Z06. GM has carefully phrased tacit admission of this so as not to seriously derail final sales of heavily discounted Z06's.
Look at the posted comparison slides on this thread. Note the top speed and the careful references to he Z51 package. Compare the known equipment stats of the C6 Z51.
Old May 14, 2004 | 11:01 AM
scorp508's Avatar
scorp508
Who's got the slide of the LS2 vs. LS6 dyno curves handy? I think its going to be damn close & the bottom end of the LS2 with those extra cubes might make the difference once they are out for a while. I doubt GM has rented many 1/4 tracks during C6 testing. Once somebody who can tear through the gears good gets one of these on a real track for a few months I think we'll see that 12.6 drop dramatically.
Old May 14, 2004 | 11:09 AM
REL44's Avatar
REL44
Default Re: (scorp508)
Is the C6 really going to be slightly lighter than the current Z06? I thought it was slightly lighter than the base C5, but not the Z06. I think in a straightline test, they will be even, and it will come down to the driver. On the track, I think a C6 will need the Z51 and some wider tires to best the Z06.
Old May 14, 2004 | 01:49 PM
peccles's Avatar
peccles
Default Re: (REL44)
I hope when one of the car mags puts the new C6 w/Z51 up against its competition they throw
in an '04 Z06 just for fun. A C6 w/Z51, '05 911 S w/active suspension, and '04 Z06 would
be a good shootout.
Old May 14, 2004 | 02:55 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: (peccles)
They will match each other overall. The C6 base will be worse in some areas and better in others.
Old May 14, 2004 | 02:56 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
I agree, its shows alot...
Old May 14, 2004 | 03:09 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
I think it will be as quick as the Z06 in acceleration and run away from the Z in top end.
Old May 14, 2004 | 03:12 PM
08msmZ06's Avatar
08msmZ06
This proves my point: the heading says preliminary. I'm pretty sure these
numbers are achieved with powershifting, which the car mags. won't do. Also,
remember that GM claimed the '02 Z06 would do 0 - 60 in 3.9. If they did
reach sub 4s in the '02, then it was done with powershifting. I don't think any
car mag. ever achieved better than 4.2/12.4 (0 - 60/quarter) for the '02 - '04
Z06. And, I doubt any car mag. will run better than 4.4/12.7 or so in the base
C6 models, regardless of the performance package.
Old May 14, 2004 | 03:17 PM
Scissors's Avatar
Scissors
I don't think any car mag. ever achieved better than 4.2/12.4 (0 - 60/quarter) for the '02 - '04 Z06.
Car and Driver achieved 0-60 in 4.0 seconds in Dec 2001
Car and Driver achieved 1/4 mile in 12.4@116 in Dec 2001
Car and Driver achieved 0-60 in 4.07 seconds in Feb. 2002
[Modified by Scissors, 3:19 PM 5/14/2004]
To C6/Z06 performance comparison...
Old May 14, 2004 | 03:33 PM
wildman378's Avatar
wildman378
Default Re: C6/Z06 performance comparison... (Scissors)
In 01 the base c5s time was .2 faster to 60 and .2 faster in the quarter mile due to the hp and torque increase.
So, picture when gm bumps up the power on the base c6 which IMO should beat the current z06 already.
6.0 liters 400hp .......it's just 5hp less than a 04 z06 and it weighs a good bit less. So my bet is for the base c6........and can't wait for the c6 z06 whew!
Old May 14, 2004 | 03:34 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
I think a C6 with all the Z51 bits PLUS the same tires that the Z06 uses would
would match a Z06 and of course pull away at the end because of the 15mph higher top speed.
Old May 14, 2004 | 04:02 PM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
Default Re: (TRAYC6)
The dyno curves you are looking for are in a thread in the C6 tech section in a thread started by Jim Hall. Take a look. The LS2 torque curve has huge advantages over the LS6 curve in a VERY large portion of the rpm range. The horsepower curves are basically identicle. With the C6 being about 150 to 200lbs heavier than the C5 Z06, the accleration numbers should favor the currernt Z06, but I doubt it will be a big deal. It will probably be more of a matter of drivers and not the vehicles. If the C6 can drop 100lbs easily, then the C6 will be a clear winner.
Todd
