Born Date
THANKS
Also, you may drop order HGPFBH from the email you send out about orders.
Jim
Jim
VEHICLE BUILD
Merchandising Model : 1YY07 -2005 CORVETTE COUPE
Gross Vehicle Weight Rating : 1665 kg (3671 lb) Order Number : HKGJ17
Build Date : 08/25/2004 Build Plant : 155Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT CC3 - TRANSPARENT REMOVABLE ROOF PANEL (REPLACES STD ROOF PANEL)
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
D42 - LUGGAGE SHADE & PARCEL NET FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM KA1 - HEATED SEATS
K63 - 110 AMP GENERATOR LS2 - 6.0 LITER SFI V8 - 400 HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
NK4 - LEATHER WRAPPED STEERING WHEEL NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QG7 - POLISHED ALUMINUM WHEELS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UG1 - HOMELINK TRANSMITTER
UJ9 - LOW TIRE PRESS. INDICATOR US3 - ANTENNA DIVERSITY
US9 - RDS AM/FM STEREO W/6-DISC IN- DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) UV6 - HEAD UP DISPLAY
U2K - XM SATELLITE RADIO-120 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VA5 - ENGLISH LANGUAGE LABEL
VDD - VEHICLE INFORMATION DVD VK3 - LICENSE PLATE BRACKET
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XFV - FRONT TIRE - P245/40ZR18 YFX - REAR TIRE - P285/35ZR19
02I - RED INTERIOR TRIM 023 - RED LEATHER TRIM SEATING
1SB - PREFERRED EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING 1SZ - PREFERRED EQUIPMENT SAVINGS
27U - PRECISION RED
Oh yeah kinda off the subject but where can I find the production numbers.
BUT: while you are checking...can you give me details and born date for mine!
VIN 1G1YY24U255103749
And I am calling to order some parts!
My C6 coupe arrived at the dealer on Friday, Oct. 29th.
Thanks a lot!!!
VEHICLE BUILD
Gross Vehicle Weight Rating : 1679 kg (3702 lb) Order Number : HKHPG9
Build Date : 09/13/2004 Build Plant : 155Y
OPTION CODES
D42 - LUGGAGE SHADE & PARCEL NET FE3 - SPORT SUSPENSION
J55 - HEAVY DUTY POWER BRAKES KA1 - HEATED SEATS
KNP - TRANSMISSION OIL COOLING SYSTEM KPS - COOLER OIL, ENGINE
MN6 - 6-SPEED MANUAL TRANSMISSION MZ6 - 6 SPD MANUAL TRANSMISSION
UG1 - HOMELINK TRANSMITTER UJ9 - LOW TIRE PRESS. INDICATOR
US3 - ANTENNA DIVERSITY US9 - RDS AM/FM STEREO W/6-DISC IN- DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO)
UV6 - HEAD UP DISPLAY U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VDD - VEHICLE INFORMATION DVD
VK3 - LICENSE PLATE BRACKET VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGN - FRONT TIRE - P245/40ZR18 BW HI-PERFORMANCE
YGJ - REAR TIRE P285/35ZR19 BW PERFORMANCE Z51 - Z51 PERFORMANCE PACKAGE (INCLUDES:LARGER CROSS-DRILLED BRAKE ROTORS,PERFORMANCE-TUNED: TIRES, STABILIZER BARS,SPRINGS, SHOCKS, GEAR RATIOS)
31I - LT CASHMERE INTERIOR TRIM 313 - CASHMERE LEATHER TRIM SEATING
41U - BLACK
VEHICLE BUILD
Merchandising Model : 1YY07 -2004 CORVETTE COUPE
Gross Vehicle Weight Rating : 1685 kg (3715 lb) Order Number : GSST8R
Build Date : 12/17/2003 Build Plant : 145Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C2L - ROOF PACKAGE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
G90 - REAR AXLE-3.15 RATIO G92 - AXLE: 3.15 PERFORMANCE RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS1 - 5.7L LITER SFI V8 - 350HP
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QF5 - HIGH POLISHED ALUMINUM WHEELS
SLM - STOCK ORDERS T82 - TWILIGHT SENTINEL
UN0 - AM/FM STEREO W/CD PLAYER UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U1S - CD 12 DISC CHANGER, REMOTE U52 - ELECTRONIC INSTRUMENTATION
VDC - VEHICLE INFORMATION CD VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME: FRONT V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE: (INCLUDES STIFFER SPRINGS AND STABILIZER BARS) 1SB - PREFERRED EQUIPMENT GROUP * MEMORY PACKAGE * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR * HEAD UP DISPLAY * STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
1SZ - PREFERRED EQUIPMENT SAVINGS 10U - ARTIC WHITE
92I - LT GRAY INTERIOR TRIM 923 - LT GRAY SEATING TRIM
Born Date 09/23/2004
VEHICLE BUILD
Gross Vehicle Weight Rating : 1683 kg (3711 lb) Order Number : HNTCGN
Build Date : 09/27/2004 Build Plant : 155Y
OPTION CODES
BGR - BOWLING GREEN PLANT CF7 - REMOVABLE ROOF PANEL
D42 - LUGGAGE SHADE & PARCEL NET E2C - ORDER TO DELIVERY - EXPEDITE
G90 - REAR AXLE-3.15 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE M32 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
R9Z - POMS EXPEDITE - SOLD ORDERS SLL - SOLD ORDERS
U52 - ELECTRONIC INSTRUMENTATION U65 - SPEAKER SYSTEM 7, PREMIUM
VA5 - ENGLISH LANGUAGE LABEL VDD - VEHICLE INFORMATION DVD
27U - PRECISION RED 31I - LT CASHMERE INTERIOR TRIM
My C6 coupe arrived at the dealer on Friday, Oct. 29th.Born 10/11/2004
VEHICLE BUILD
Gross Vehicle Weight Rating : 1675 kg (3693 lb) Order Number : HQBNZB
Build Date : 10/12/2004 Build Plant : 155Y
OPTION CODES
D42 - LUGGAGE SHADE & PARCEL NET FE2 - SUSPENSION SYSTEM RIDE, HANDLING
F55 - MAGNETIC SELECTIVE RIDE CNTRL GU2 - REAR AXLE 2.73 RATIO
KA1 - HEATED SEATS K63 - 110 AMP GENERATOR
LS2 - 6.0 LITER SFI V8 - 400 HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M32 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NC7 - FEDERAL EMISSIONS OVERRIDE
NE1 - 50-STATE EMISSIONS NK4 - LEATHER WRAPPED STEERING WHEEL
NU4 - CAL EMISSION SYSTEM, LEV2 PLUS N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QG7 - POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFV - FRONT TIRE - P245/40ZR18
YFX - REAR TIRE - P285/35ZR19 1SB - PREFERRED EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
193 - EBONY LEATHER TRIM SEATING 41U - BLACK
VEHICLE BUILD
Gross Vehicle Weight Rating : 1664 kg (3669 lb) Order Number : HHZCDT
OPTION CODES
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN QG6 - 5-SPOKE ALUMINUM WHEEL
SLM - STOCK ORDERS UG1 - HOMELINK TRANSMITTER
VDD - VEHICLE INFORMATION DVD VM3 - CONSUMER INFORMATION LABEL
1G1YY24UX55104289
Thank you very much, If it is too late that's okay.
