Born Date
Old Dec 1, 2004 | 03:54 PM
Another Yellow's Avatar
Another Yellow
St. Jude '03-'04-'05-'06
I always understood that the "born date" meant the day the car was first started on the line and came to life. (which is now only a few cars fron the end with the C6) Sort of like when your child was born and let out the frist cry.
Old Dec 1, 2004 | 03:57 PM
SuperChevyICM's Avatar
SuperChevyICM
Originally Posted by bangbgC6
If it isn't too much trouble to look up my vin #is
1G1YY24UX55104289
Thank you very much, If it is too late that's okay.
Born Date is 9/30/2004
Old Dec 1, 2004 | 04:01 PM
SuperChevyICM
I think that is what they show in the production system when it shows 3800 (produced). The actual Build date shows later when it has been finalized and invoiced.
Old Dec 1, 2004 | 05:32 PM
coolcat's Avatar
coolcat
Thank you! However I have one question. If the date on the build sheet is the date the car came off the line then what's that date stamped on the drivers door?
Old Dec 1, 2004 | 05:52 PM
SuperChevyICM
I think that the build sheet date is the invoice or completion date for the build. The date on the door might be the same one that shows in the system as 3800 (produced). If it is an older VIN# I cannot look it up because it will have dropped from the production system.
Old Dec 1, 2004 | 06:19 PM
JSMDMD's Avatar
JSMDMD
Default Can you check...
Can you check the finish date for 1G1YY24U555105561?
Thanks! I have the build sheet but there aren't any dates on it.
Old Dec 1, 2004 | 07:15 PM
SuperChevyICM
VIN 1G1YY24U555105561
Born on 10/13/2004
VEHICLE BUILD
Merchandising Model : 1YY07 -2005 CORVETTE COUPE
Gross Vehicle Weight Rating : 1674 kg (3691 lb) Order Number : HNCR4B
Build Date : 10/13/2004 Build Plant : 155Y
OPTION CODES
AG2 - SIX-WAY POWER PASSENGER SEAT AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
CF7 - REMOVABLE ROOF PANEL CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED OUTSIDE REARVIEW MIRRORS
D42 - LUGGAGE SHADE & PARCEL NET E2C - ORDER TO DELIVERY - EXPEDITE
FE3 - SPORT SUSPENSION GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT
J55 - HEAVY DUTY POWER BRAKES KNP - TRANSMISSION OIL COOLING SYSTEM
KPS - COOLER OIL, ENGINE K63 - 110 AMP GENERATOR
LS2 - 6.0 LITER SFI V8 - 400 HP MN6 - 6-SPEED MANUAL TRANSMISSION
MZ6 - 6 SPD MANUAL TRANSMISSION NC7 - FEDERAL EMISSIONS OVERRIDE
NK4 - LEATHER WRAPPED STEERING WHEEL NU4 - CAL EMISSION SYSTEM, LEV2 PLUS
QG6 - 5-SPOKE ALUMINUM WHEEL R8C - CORVETTE MUSEUM DELIVERY
R9Z - POMS EXPEDITE - SOLD ORDERS SLL - SOLD ORDERS
UJ9 - LOW TIRE PRESS. INDICATOR US3 - ANTENNA DIVERSITY
US8 - AM/FM CD/MP3 RDS RADIO U52 - ELECTRONIC INSTRUMENTATION
U66 - SPEAKER SYSTEM 7, CUSTOM VDD - VEHICLE INFORMATION DVD
VG8 - NOTICE TO BUYER LABEL VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGN - FRONT TIRE - P245/40ZR18 BW HI-PERFORMANCE
YF5 - 50-STATE EMISSIONS YGJ - REAR TIRE P285/35ZR19 BW PERFORMANCE
Z51 - Z51 PERFORMANCE PACKAGE (INCLUDES:LARGER CROSS-DRILLED BRAKE ROTORS,PERFORMANCE-TUNED: TIRES, STABILIZER BARS,SPRINGS, SHOCKS, GEAR RATIOS) 1SA - EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS
1SZ - PREFERRED EQUIPMENT SAVINGS 10U - ARTIC WHITE
31I - LT CASHMERE INTERIOR TRIM 313 - CASHMERE LEATHER TRIM SEATING
Old Dec 1, 2004 | 07:24 PM
Another Yellow
Any date that may be on the build sheet is not the date the car came off the line.
The build sheet is produced before the car starts on the line, and there would be no way of knowing when it will come off. There are times when the line stops, overtime, slowdowns, etc. all of which would affect when the car finally comes off.
The date on the door only has the month and year produced.
Old Dec 1, 2004 | 10:12 PM
Vette_DD's Avatar
Vette_DD
I was hoping the day could be found somewhere, but I never found it.
Old Dec 1, 2004 | 10:41 PM
Vespa-Vette's Avatar
Vespa-Vette
Wow! Thanks for looking all these up.
How about the build/born date for 1G1YY24U855104128
Thanks!
Old Dec 2, 2004 | 05:56 AM
JSMDMD's Avatar
JSMDMD
Default Yahoo....
Thanks for looking that up!
Geez... my car was born on the 13th...
Good thing I ain't superstitious...
Old Dec 2, 2004 | 08:38 AM
vettnutt's Avatar
vettnutt
I'd really appreciate a check of the 'born on date' for VIN 3907. Thanks...
Old Dec 2, 2004 | 09:39 AM
  #33
SuperChevyICM
Thanks!
VIN 1G1YY24U855104128
Born on 9/28/04
VEHICLE BUILD
Gross Vehicle Weight Rating : 1683 kg (3711 lb) Order Number : HNNZKK
Build Date : 09/30/2004 Build Plant : 155Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT CF7 - REMOVABLE ROOF PANEL
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE3 - SPORT SUSPENSION FE9 - 50-STATE EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT J55 - HEAVY DUTY POWER BRAKES
KA1 - HEATED SEATS KNP - TRANSMISSION OIL COOLING SYSTEM
MZ6 - 6 SPD MANUAL TRANSMISSION NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QG7 - POLISHED ALUMINUM WHEELS R8C - CORVETTE MUSEUM DELIVERY
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND UG1 - HOMELINK TRANSMITTER
UV6 - HEAD UP DISPLAY U3U - AM/FM CD WITH DVD NAVIGATION, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO)
U52 - ELECTRONIC INSTRUMENTATION U65 - SPEAKER SYSTEM 7, PREMIUM
VA5 - ENGLISH LANGUAGE LABEL VDD - VEHICLE INFORMATION DVD
VK3 - LICENSE PLATE BRACKET VM3 - CONSUMER INFORMATION LABEL
YGJ - REAR TIRE P285/35ZR19 BW PERFORMANCE Z51 - Z51 PERFORMANCE PACKAGE (INCLUDES:LARGER CROSS-DRILLED BRAKE ROTORS,PERFORMANCE-TUNED: TIRES, STABILIZER BARS,SPRINGS, SHOCKS, GEAR RATIOS)
1SB - PREFERRED EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING 1SZ - PREFERRED EQUIPMENT SAVINGS
19I - BLACK INTERIOR TRIM 193 - EBONY LEATHER TRIM SEATING
41U - BLACK
Old Dec 2, 2004 | 09:40 AM
  #34
SuperChevyICM
VIN 1G1YY24U555103907
Born On 9/27/2004
VEHICLE BUILD
Gross Vehicle Weight Rating : 1671 kg (3685 lb) Order Number : HNJBMW
Build Date : 09/27/2004 Build Plant : 155Y
OPTION CODES
BGR - BOWLING GREEN PLANT CC3 - TRANSPARENT REMOVABLE ROOF PANEL (REPLACES STD ROOF PANEL)
D42 - LUGGAGE SHADE & PARCEL NET FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS G90 - REAR AXLE-3.15 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
KA1 - HEATED SEATS K63 - 110 AMP GENERATOR
LS2 - 6.0 LITER SFI V8 - 400 HP MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M32 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NK4 - LEATHER WRAPPED STEERING WHEEL
QG7 - POLISHED ALUMINUM WHEELS SLM - STOCK ORDERS
UV6 - HEAD UP DISPLAY U2K - XM SATELLITE RADIO-120 CHANNELS OF GO ANYWHERE ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U3U - AM/FM CD WITH DVD NAVIGATION, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM VA5 - ENGLISH LANGUAGE LABEL
VDD - VEHICLE INFORMATION DVD VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFV - FRONT TIRE - P245/40ZR18
YFX - REAR TIRE - P285/35ZR19 1SB - PREFERRED EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING
1SZ - PREFERRED EQUIPMENT SAVINGS 19I - BLACK INTERIOR TRIM
193 - EBONY LEATHER TRIM SEATING 67U - MACHINE SILVER METALLIC
Old Dec 2, 2004 | 09:51 AM
  #35
vettnutt's Avatar
vettnutt
Thanks so much. You da man!
Old Dec 2, 2004 | 11:17 AM
  #36
Vespa-Vette
Thanks.
Old Dec 7, 2004 | 06:10 PM
  #37
harryjen's Avatar
harryjen
8th Gear
Default Vehicle Build
Can i get one Vin#1G1YY3382L5103435?
Thanks, Harry
