yum
Old Dec 20, 2004 | 12:29 PM
jdplays's Avatar
jdplays
Default yum
2006 Chevrolet Corvette Z06
Brenda Priddy and Co.
500-horse Corvette to tour auto shows next spring
Chevrolet will give Corvette aficionados a preview of the all-new 2006 Z06 model on the auto show circuit this coming spring.
The big news lurks under the hood, where an all-new LS7 7.0-liter V-8 (the displacement works out to 427 cubic inches) reportedly churns out 500 horsepower.
The ultimate 'Vette also will be fitted with wider tires and larger Brembo brakes.
Body modifications include a high-rise hood, deep side skirts and cooling ducts ahead of the rear wheels.
-- Paul Lienert
[IMG]
Old Dec 20, 2004 | 01:08 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Can't Wait
I'm looking forward to that. Only way it could be better was if Scissors were to drive
Old Dec 20, 2004 | 09:22 PM
Convert14's Avatar
Convert14
Old Dec 20, 2004 | 09:42 PM
The Garage Master's Avatar
The Garage Master
I vote for Chad to drive.
Old Dec 20, 2004 | 10:12 PM
lager99's Avatar
lager99
St. Jude Donor '06
That's amazing news!
Old Dec 20, 2004 | 10:16 PM
jdplays's Avatar
jdplays
your opinion matters.
Old Dec 20, 2004 | 10:32 PM
lager99's Avatar
lager99
St. Jude Donor '06
You must have thought I was being sarcastic...
Oh look I found a post from January...almost 1yr ago...it says the same thing.
I was talking with i guy from GM Powertrain today. I have know him for years and he knows i am into Corvettes. While its not really breaking news, he told me the Z06 will have a 7.0 litre engine and the number being mentioned is 500 hp.
LINK
Old Dec 20, 2004 | 10:51 PM
jdplays's Avatar
jdplays
LINK
you still must think people care what you think.... your like that little know-it-all b_tch in school nobody liked. I wasn't a vett owner last January. The post wasn't meant for someone who has spent everyday here for the last year, not everyone knows-it-all, like you.
Old Dec 20, 2004 | 11:01 PM
lager99's Avatar
lager99
St. Jude Donor '06
All you have to do is read the threads in the C6 ZO6 section...any of them.
http://forums.corvetteforum.com/showthread.php?t=971640
http://forums.corvetteforum.com/showthread.php?t=973770
http://forums.corvetteforum.com/showthread.php?t=972445
http://forums.corvetteforum.com/showthread.php?t=970356
http://forums.corvetteforum.com/showthread.php?t=969628
http://forums.corvetteforum.com/showthread.php?t=969490
http://forums.corvetteforum.com/showthread.php?t=965922
http://forums.corvetteforum.com/show...5&page=1&pp=20
There's more if you need it...
Old Dec 20, 2004 | 11:02 PM
lager99's Avatar
lager99
St. Jude Donor '06
Here's the Cole's notes for you:
"Here you go:
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
Chassis & Suspension development by Pratt & Miller,
Aluminum Hydroformed frame produced by DANA
- 345/30x19 Rears
- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors (possibly Brembo)
Engine Development by KaTech
To be hand built by new HP Engine Plant
LS7 427ci/ 7.0L. 500HP/500 Ft Lbs (512 HP derated to 500HP)
- 2 OHV (3 OHV not necessary for target HP)
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 46 mm (1.81") Titanium Intake valve
- 41 mm (1.61") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
Shawn"
Old Dec 20, 2004 | 11:05 PM
jdplays's Avatar
jdplays
so lager, have you heard there is going to be a new c6zo6??? it's supposed to have like 500hp!!! pretty cool...eh bro.
Old Dec 20, 2004 | 11:08 PM
lager99's Avatar
lager99
St. Jude Donor '06
Old Dec 20, 2004 | 11:10 PM
jdplays's Avatar
jdplays
"Here you go:
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
- 345/30x19 Rears
- 11.0:1 CR
- Forgrd Crank
- Titanium Rods
- Dry Sump
- Ram Air
Shawn"
even though your kinda being a d_ck, thanks for that info, havn't heard all that yet! :o
Old Dec 20, 2004 | 11:11 PM
lager99's Avatar
lager99
St. Jude Donor '06
You'll get used to it.
Old Dec 20, 2004 | 11:20 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
What do you mean kind of being?
Old Dec 20, 2004 | 11:30 PM
IrishMac's Avatar
IrishMac
Moderator Emeritus
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
We don't have that much time.
Old Dec 21, 2004 | 12:04 AM
lager99's Avatar
lager99
St. Jude Donor '06
Old Dec 21, 2004 | 07:41 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
play nice or play somewhere else
To yum
