Corsa tips alignment preference?
Old Jan 11, 2005 | 08:48 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Default Corsa tips alignment preference?
Now that the Corsas are installed, I need to do a bit of tweaking to get them aligned squarely. While I am at it, what do the Corsa owners prefer in regard to tip alignment?
1. Even with the rear valance?
2. Pulled in as far as possible?
3. Extended out as far as possible?
Thanks for any replies. Figure you folks who have owned a vette already probably have a pretty good idea as to what looks best.
Old Jan 11, 2005 | 09:04 PM
Short-Throw's Avatar
Short-Throw
The tips I had on my C5 needed adjustments every so often. The C6 system seems to be a better fit so far. Make sure the tips aren't too high so you won't melt your rear end.
When I'm looking at my car from an eagle's view, as I peer down the rear end, my tips stick out just slightly. Remember there is a small concavity from the outside pipes to the inners. There seems to be less play in the newer system, so you will not have that much too say about it. I think it's all for the better.
http://www.natetross.com/_wsn/page3.html
http://www.natetross.com/_wsn/page2.html
Old Jan 12, 2005 | 01:00 AM
rwpatte's Avatar
rwpatte
Good information
Old Jan 12, 2005 | 08:40 AM
Boozman's Avatar
Boozman
How much of a difference is the sound from the C5 with Corsas installed
Old Jan 12, 2005 | 09:31 AM
ByByBMW's Avatar
ByByBMW
Default C5 sound difference
Sorry, never had a C5 so can't answer that. Difference from stock C6 is wonderful, now sounds like it has some muscle under the hood.
Old Jan 12, 2005 | 09:58 AM
Boozman's Avatar
Boozman
Thanks I had corsa on my c5 and it sounded more like an expensive import than a muscle car, that's why I was asking.
Old Jan 12, 2005 | 10:51 AM
Short-Throw
Boozman, The C6 system sounds a little deeper and not so 'gurglely'
than the C5. On WOT above 4000rpms it is pretty sweet. Overall, a much deeper and smoother sound across the power band. Also, not as much pop on the decel. I'm very happy with them.
Old Jan 12, 2005 | 11:09 PM
ByByBMW's Avatar
ByByBMW
Default Bump & thanks
Thanks Short-throw for you input. I am trying to bump this cause I just can't believe no one else wants to give me some advice on the best alignment for my Corsas. Come on folks, is this topic THAT boring?
To Corsa tips alignment preference?
