C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6 Front License Plate Bracket
Old 09-14-2009, 05:49 AM
  #261
Top Flight Reproductions
Top Flight Reproductions's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by jlutherva
Has anybody had any issues with the bottom part of the deformable bumper not being flat? The design of this part seems to require it to be relatively flat for the double sided tape to adhere. Before I stripped off the tape, I held it up against the bumper and it rocks back and forth. If you hold it all the way against on side, there's almost a 1/4-inch gap on the other side. If I push hard enough, it will flatten the bumper out. I just wonder how long the double sided tape will hold given the continuous force on it.
Thoughts?
Jim
Hi Jim, that's a common question and as you mentioned if you push hard it will flatten out. The adhesive is agressive and will hold very nicely.
Old 09-14-2009, 09:46 AM
  #262
jlutherva
jlutherva's Avatar
OK, Thanks!
Jim
Old 09-19-2009, 09:39 AM
  #263
jlutherva
jlutherva's Avatar
Yes, that did work and it's holding nicely. I wedged a 2x4 under the plate to the floor to push it up for several hours and now it's holding well.
I have always been skeptical about the claims that this placement did not significantly raise temperatures so I did my own experiment. After all, if you take something the size of a license plate and stick it in your main air inlet, it only makes sense that it could raise temps if air flow was approaching a critical level.
Freeway driving, 65-70 mph, 80 degrees F, with the bracket, oil temp was running 167 degrees F. W/O the plate mounted, it stabilized at 165, so I have to agree, no significant temp increase under normal operating conditions at reasonable ambient temperatures. Obviously, extreme driving conditions could and probably would affect temps, but hey, that's why it's removable.
It may actually be an advantage to have the plate in the winter since it could help increase the oil temp faster, for those of you who actually drive these cars in the winter
Jim
Old 09-20-2009, 11:25 AM
  #264
Jim
Thanks for clearing that up Jim
Old 12-29-2009, 08:00 AM
  #265
AlBinVA
AlBinVA's Avatar
Default Call me crazy, but I am not a big fan of the color-matched frame..
It seems to accentuate the existence of the license plate over the front fascia.
Are there any pics available with the bracket/plate only? A perfect example would be that combo on a LMB Z.
Al
Old 12-29-2009, 12:15 PM
  #266
Al
Hi Al, I do not have a comparison in LMB but I can show you in MY
Without GM colered frame
With GM colored frame
Old 01-27-2010, 08:55 AM
  #267
Cdn Z06 Mike
Cdn Z06 Mike's Avatar
Peter, I was on your site. I see where I order the bracket for the Z06 and it shows the optional colour matched frame but where do I find the optional colour matched frame if I want to order and how much extra is the frame?
Edit...found it.. Thanks
Old 03-01-2010, 04:39 AM
  #268
KIWIBOB
KIWIBOB's Avatar
Ok guys tell me how much air flow to the radiator is restricted buy installing a plate in that area.
Old 03-01-2010, 07:05 AM
  #269
I know this thread is some what long however, if you spend some time and read it you will find a number of people using our bracket that have posted here stating that they have seen no increase in engine temp because of the bracket, air flows around it
Old 03-14-2010, 08:14 PM
  #270
CanadianVetster
CanadianVetster's Avatar
just got mine, installed in no time....... love the look....... way better
then alternatives.......... Dont know about running temps.... too new to tell.........
Old 03-14-2010, 08:22 PM
  #271
EdsC6Z06
EdsC6Z06's Avatar
St. Jude Donor '05-'06-'08-'10
I broke down and ordered one for my new Z. Hate the idea of running a front plate, but hate being pulled over more. A bit pricey though.
Old 03-15-2010, 12:20 PM
  #272
Thank you for the orders
Old 03-21-2010, 10:13 PM
  #273
JetBlue427
JetBlue427's Avatar
Will you ship to Canada? Any Canadians experienced any issues recieving there plate across the border? and how long does it take to ship
Old 03-21-2010, 10:36 PM
  #274
Hi Jetblue, we ship all orders to Canada USPS and they typ. arrive in 4-5 days, brackets are in stock and ready to ship
Old 04-04-2010, 01:05 PM
  #275
TOBASCO
TOBASCO's Avatar
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
Instead of reading 47 pages of info (sorry!), I thought I'd just ask the main questions I've got:
1. Does this bracket work for the Grand Sport/Z06?
2. Are the bracket and the color-matched frame 2 separate items?
3. It looks like the total for both frame and bracket (just the front) with shipping would be close to $250 - am I close?
4. Are there any discounts for ordering the bracket & frame together? Along with the rear plate frame?
Thanks!
Old 04-04-2010, 01:14 PM
  #276
zero05
zero05's Avatar
nice. looks great
Old 04-04-2010, 07:02 PM
  #277
Thanks!
1. Yes, P/N 0010003-3
2. yes, two seperate items.
3. Yes.
4, No, sorry
To C6 Front License Plate Bracket
Old 04-07-2010, 05:05 PM
  #278
In Stock!
The Top Flight Reproductions C6 front license plate bracket is the best looking mount available. It follows the contour of the front bumper. Installs easily without lifting the car. Requires no drilling for attachment like some others do. Our bracket is priced considerably lower than other after market solutions and is made in the USA
All three Top Flight Reproductions front license plate brackets are in stock and ready to ship. Visit our website at www.topflightrepro.com or call 781-279-1279 and ask for Ray.
C6 Z06/ZR1 Removable Front License Plate Mounting Bracket
Old 04-07-2010, 05:55 PM
  #279
JetBlue427
JetBlue427's Avatar
ordered my plate bracket this morning...hopefully it went through paypal ok? its the one being shipped to Manitoba Canada just wondering if you recieved the order
Old 04-07-2010, 08:23 PM
  #280
Hi S.B.. order received, thank you. Will ship tomorrow USPS
Quick Reply: [Z06] C6 Front License Plate Bracket
