[Z06] Need Assistance--Car Will Not Start
I loaded 2006 Z06 in enclosed trailer to get ready to go to track days at Barber Motor Sports Park this Friday and Saturday. Got out of car by crawling out the rear hatch. Needed to move car to a better position to tie it down. Crawled back in through rear hatch, started car and moved it. I needed to move car again, crawled in and the car would not start. Battery seems okay-lights and everything else are working fine-no problems starting before. I tried both fobs and accessing car through driver's door-still it would not start.
Anyone have any idea what problem may be and solution.
St. Jude Donor '07
There seems to be some interaction with the powering off and the opening/closing of the door, Try to hold the bottom of the start button untill accessory power comes on, then again untill it goes off. Then try to start it.
I dont have any evidence this will work, but it is the first thing I would do to try to cycle the power to the computer.
Sounds like the computer did not recognize the FOB the second time. open/close using the FOB (again), then with the FOB in hand try to push the start botton. Good luck
