[Z06] Bleed Valve Caps ... Where's the best place to get them
C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Is the dealer the only place to buy the little rubber caps that go over the caliper bleed valve?
Yes, and they are ridiculously overpriced. HOWEVER, a 1/4" vacuum line cover will fit just fine if you cut it a bit, and they are really cheap. I found a box of black ones at a local Kragen and two of them are now on my calipers . . .
