[Z06] ZR1 blower on a Z06
ZR1 blower on a Z06
When will the ZR1 blower be available and what will it take to get it running on a Z06, other than new heads and a lower compression ratio?
The ZR1 uses an Eaton blower but I'm not sure its a TVS model.
If the ZR1 blower is a TVS series, and the water-air cooler really is efficient, it'd be a nice product to drop in a Z. Even then I imagine you'd need a pretty big pulley to keep the boost down to 4-6 psi.
Anyone have hard numbers on water-air intercooling?
The LS9 and LS7 have different intake port shapes and locations, it will not be a direct bolt-on. The lower intake manifold would have to be custom made to adapt it to the LS7.
Also, the serpentine belt setup is completely different as well. The LS9 has a wider belt, and a different route. It also uses two belts.
The LS9 is a TVS style blower, by the way.
I've been speaking with Magnacharger, they estimate an LS7 setup might be ready around March 09. I'm looking forward to that. I've had APS twin-turbos, and two Magna combos. Both are excellent, the Magna is just much easier to install.
Tony
Tony
Callaway told me that they are testing a LS7 kit now, but the release date isn't going to be until after the holidays. I am sure that they and Magnusson are working together on this kit.
Also the ZR1 supercharger could be installed on a LS7 if one swapped out the heads to a set of LS3/L92 heads which are plentiful and cheap to purchase. If the heads are swaped it would be a direct bolt on. I doubt much power would be lost because the blower would overcome any cylinder head ineffeciencies. The other issue to make this work would be to get all the drive parts, the intercooler parts and controls. It could be done but its not going to be cheap. All the parts are available from your local GM dealer.
You could get a Kenne Bell kit, swap out the LS7 heads with some old school big runner cathedral port heads and bolt it on. Or go and get a set of LS3 heads and bolt on a Maggie kit for a LS3 car which from what I have head can be upgraded to a TVS1900. Which has the exact same bolt pattern as a MP122 blower. It would be a easy swap.
Premium Supporting Vendor
Other things I can think of:
LS9 front drive
MAP adapter (which we have)
Figure out how to adapt the throttle body
Air intake system
Heat exchanger, water tank, water pump
Calibration (several issues I can think of)
Hood clearance
Wiper cowl clearance (since you are spacing the SC up)
My initial response to this thread was in response to your original question
"When will the ZR1 blower be available for teh Z06"?
I stated that there were other options.
We have TVS systems in stock and ready for installation on the LS7 powered Z06's as well as the LS2 & LS3 powered C6's. With our TVS system, we safely and reliably achieve 850hp with no boost lag and 760ft/lbs of tq which comes on at ridiculously low rpm's. We compliment the awesome power numbers mentioned with our own custom 8-rib billet belt system as well as our TVS cooling and oiling systems to complete the turn-key conversion package. We're ready when you are!
[Flamesuit]
can an LS7 take that much boost without forging the pistons/rods?
I'm curious as I thought GM tested with an LS7, but scrapped it for some reason and went with a smaller bore for more durability. definitely interested in MTI's setup though. Stupid Daily Driver pledge... :
[/Flamesuit]
[/Flamesuit]
[Flamesuit]
[/Flamesuit]
[/Flamesuit]
From the experts:
"In lieu of the 7.0-liter LS7, Chevy opted for their 6.2-liter block as the foundation of the LS9 for its lower cost and thicker cylinder walls. The latter improves head gasket sealing against the higher combustion pressures found in the boosted LS9. "
All I can say is Holy Sh**...the car feels incredible...!!
The drivability is better than the cam only set up I had in my '07. Ya'll have done one hell of a job on this TVS system. I really like how ya'll have gone above and beyond just typically "bolting on" a FI kit. From the improvements in cooling to all the LS7 oiling improvements and tuning I really like this set up...
Don't let Mike hear this but his Z06 is a bonified, street monster in sheeps clothing...yes I'm jealous
Great job MTI...!!
From the experts:
