[ZR1] *ForgeLine EV1 One Piece Wheels*
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Hi guys,
Need a set of incredibly light weight 18" wheels for your Z06 or ZR1? Take a look at ForgeLine's new EV1 one piece forged wheel!
I have a set of 18x10.5 and 18x13 ready for pick up in Gunmetal grey with ZERO WAIT TIME!
Cyber Grey Z06 with EV1 wheels
EV1 with 15" Brembo 6 Piston kit
EV1 in Gunmetal Grey
The EV1R is a fully forged one piece mono-block wheel. Forged from 6061 T6 aerospace aluminum and then precision machined to exact specifications.
Features include:[LIST][*]-Extreme Strength[*]-Extreme Stiffness[*]-Extreme Brake Caliper Clearance[*]-Large un-obstructed lugnut area for easy access to lugnuts and faster pit stops.[*]- Works with all TPMS sensors[*]- Available powder coated or Race Polished (Ball Polished)
Available in 18x9.0, 18x10.0, 18X10.5, 18x11, 18x11.5, and 18x13.
*These do clear the ZR1 15.5" brakes with ZERO ISSUES!
Retail for $4600, call for special pricing!!
Very nice looking wheel indeed!
What offsets are available? What tires in what size are on the Z pictured?
EDIT: Also, what do they weigh? Someone was going to ask this, you knew it!
Former Vendor
Offsets are custom to each car and owner, depending on what size you want and where you want the wheel to sit.
The car pictured has 295/30/18 fronts and 335/30/18 Michelin PSII tires.
Weights, again are going to vary depending on size, and finish. These are roughly 22 lbs each front, and just under 20 lbs on the rear due to the smaller center hub area.
I do not have stock OE weights on the ZR1, but Z06's are 25.6 lbs each front and 27.6 each rear the last set I weighed.
Former Vendor
I can do 20's in a three piece, and I can even do a hidden bolt option so that the hardware is not shown, but nothing in a one piece.
