C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Brakes
Old 07-21-2009, 03:01 PM
Silver Rocket
Silver Rocket's Avatar
Default Brakes
I had the mechanic look at my brake pads after he did an oil change. The brakes have about 24000 miles on them and he said there was about 40% left. He also said the when I replace the brake pads, the brake disk and rotors should be replaced as well. Is this true, even if your brake disk are in good shape?
Old 07-21-2009, 03:25 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Typically you do not have to change the rotors as well unless they are worn past the minimum thickness.
I have went through 2 sets of pads on my car and still have the stock rotors on the car.
Old 07-21-2009, 03:38 PM
Silver Rocket
what is the mininum thickness for the front rotors?
Old 07-21-2009, 03:40 PM
BlaznZ06
BlaznZ06's Avatar
He likes your money.
Old 07-21-2009, 05:26 PM
Former Vendor
Not sure off the top of my head, but it is typically stamped into the rotor either on the inside or edge.
Old 07-22-2009, 12:56 PM
goatts
goatts's Avatar
Forget replacing the rotors, you don't even need to get them turned if they are still in good condition.
To Brakes
Quick Reply: [Z06] Brakes
