[Z06] Where do I find the paint code for my 2008 Black Z06?
It's not on the sticker on the door, unless I'm missing something. Can someone point me in the right direction please. Thanks.
The color code should be on the glove box as an RPO Code.
The RPO Code for a 2008 black corvette is 41U.
Here is a link with RPO codes listed: C6 Corvette Registry - 2008 Facts
It's the last bunch of numbers on your glove box sticker. Since my car's also black, should read BC/CC(base coat/clear coat) U(upper)8555. Industry standard code would be WA8555. GM's been using this black for awhile, as my C5 wore it too. If your car had a factory lower accent color, you'd see another L(lower) paint code listed, too. If you use Dupli-Color lacquer touch up, no clear is really needed. If a factory pack two part urethane, you'll need a clear coat for proper shine.
