C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] November C6 Specials - www.PartsTaxi.com - Price Decrease!!!
Old Nov 10, 2009 | 01:59 PM
PartsTaxi.com's Avatar
0PartsTaxi.com
Former Vendor
Default November C6 Specials - www.PartsTaxi.com - Price Decrease!!!
Thank you again for your all your business in October. It was another great month for us at PartsTaxi, and we owe it to our customers. We had a great cruise in last weekend with the local corvette clubs. It was nice to see more the 2 dozen cars turn out when the thermostat on the sign read 27 degrees at 8am. Unseasonably cold for here, this is the beach area LOL.
In running through some of our kit pricing, I found that GM lowered our pricing on quite a few items, so I am able to pass these savings on to you. I have also added quite a few more lines of what was popular and requested last month. As always, I will match any competitors total shipped price on any GM parts, not just what is listed here.
Please feel free to contact me with any questions or for assistance. You can call, email, pm ~ whatever works for you
Genuine GM C6 Corvette PAL
17800593 - C6 Corvette Personal Audio Link - $149.58
19170234 - GM Genuine Accessory Splash Guards - $91.88
C6 Maintenance Parts
12626224 - Single UPF48R Filter - $8.38 each
To order a case of 12 UPF48R use Part Number 12packUPF48R for $95.76 total (thats $7.98 each!)
25329389 - UPF44 Oil Filter $8.22 each
89017524 - PF48 Oil Filter $4.98 each
19210283 - PF46 Oil Filter $4.78 each
15861929 - Passenger Compartment Filter - $42.62
10342024 - LS2 Air Filter Element (Need 2) - $16.42 each
15776148 - LS3 & LS7 Air Filter Element - $85.44 each
25940997 - LS9 Air Filter Element - $114.14 each
24241872 - Magnetic Drain Plug - $14.65
OEM GM Brake Pads - Standard C6 and Z51
19152862 - Front OEM Pad Kit - $161.46
89026853 - Rear OEM Pad Kit - $99.40
Ceramic Brake Pads for Stock and Z51 systems
88909667 - Front Ceramic Pad Kit - $88.37
88909668 - Rear Ceramic Pad Kit - $59.31
Base C6 ACDelco Drilled & Slotted Rotors
19183532 - Right Front - $94.19
19183533 - Left Front - $94.19
19183534 - Right Rear - $87.09
19183535 - Left Rear - $87.09
That's $362.56 for all 4!!!
2008 and newer Key & Fobs (transmitters)
25926479 - #1 Key Fob - $89.72
25926480 - #2 Key Fob - $89.72
25995382 - Key (does not come with Fob) - $38.14
Grand Sport Rear Wide Body Kit for Vert - $1243(these panels cost slightly higher then normal kit)
Grand Sport Front Wide Body Kit - $2289.72
Chrome Z06 Emblems - 25919017 - $21.56 each
427 Script Emblems - 17803320 - $115
Carbon Fiber Center Consoles
Heated Seats with no F55 = 25972649 = $397.16
Heated Seats With F55 = 25972645 = $578.61
No Heated Seats No F55 = 25972656 = $381.45
With F55 no Heated Seats = 15939772 = $389.34
HUD Display - 15934351 - $254.98
HUD Switch - 20844868 - $30.72
HUD Bezel - 19121990 - $20.04
You will need a custom harness for this application. There is a forum member here who sells them for around $75 I believe.
19116372 - GM C6 Fuse Block Cover - $29.98
Rear Wide Body Kit - This is the complete rear wide body kit. ZR1 & Z06 are the same. Kit includes rear quarters, all fasteners, seals brake ducts, scoops and wheel liners. $1148
Z06 Rear Splash Guards
15818636 - Right Rear Splash Guard - $44.33
15818637 - Left Rear Splash Guard - $43.24
11519444 - Retainers - $1.38 ea. x 10 needed
ZR1 Front Wide Body Kit - This is the complete front wide body conversion to install ZR1 panels on the front of your C6. Kit includes fenders, fascia, seals, all hardware, ornaments. COMPLETE KIT. $4790.58
Not included in ZR1 Kit, but available for extra cost;
ZR1 Front Splitter - 25938053 - $1349
ZR1 Hood - 15844745 - $3679.55
ZR1 Rocker Panels - 15845019 & 15845020 - $948.01 each
ZR1 Roof Halo - 15843296 - $1386.05
ZR1 Roof Panel - 15843295 - $2190.73
Z06 Front Wide Body Conversion - This is the front wide body kit with the Z06 panels. This includes everything for installation minus the inner plastic liner that is glued to the body/frame. $3845.82
20822934 - Upgraded Metal Sway Bar End Links - $22.78 each
ZR1 Front and Rear Sway Bar Kit - Kit Includes front and rear sway bars and insulators $199.84
Z51 Front and Rear Sway Bar Kit - Our most popular bar kit. Kit includes front and rear stabilizer bars for Z51 - $191.84
Z06 Front and Rear Sway Bar Kit - Kit includes Front and Rear Stabilizer Bars for C6 Z06 and insulators - $224.83
C6 Z06 Shocks
10313647 - Front Shock - $61.43 each
25819268 - Rear Shock - $60.42 each
Z06 Brake Upgrade Kit - Kit includes both front calipers, both rear calipers, both front rotors, both rear rotors, front and rear GM OEM pads. We prefer not to substitute ACDelco as a replacement on this kit. - $1799.99
Z51 Brake Upgrade Kit - Kit includes both front rotors, both rear rotors and all four caliper mounting brackets - $489.78
15268606 - Tire Pressure sensor for 2010 and up - $39.99
25758220 - Tire Pressure Sensor for 05-09 - $55.08
15234846 - Tire Pressure Sensor Nut 05-10- $3.73
LS7 Clutch Kit - Kit includes LS7 Clutch and Flywheel - $431.97
89059282 - LS6 Slave Cylinder - $125.01
12564455 - LS6 Master Cylinder - $127.49
14061685 - Pilot Bearing - $11.99
19172324 - Genuine GM Accessory Performance Exhaust Cat-Back - $1219
19172326 - Genuine GM Accessory Off Road Cat-back exhaust - $1219
ZR1 Spoiler Kit - ZR1 Spoiler kit includes spoiler and 10 nuts needed for installation - $429.83
Body Color Z06 Spoiler
17802347 - DSOM - $192.34
17802348 - Victory Red - $192.34
17802349 - Lemans Blue - $212.58
17802350 - Machine Silver - $192.34
17802351 - Velocity Yellow - $192.34
19158349 - Atomic Orange - $192.34
19169711 - Jetstream Blue - $192.34
19169712 - Crystal Red - $192.34
19172841 - Cyber Gray - $192.34
19211170 - Switchblade Silver - $192.34
Full Width Design Spoiler
19172807 - Primer - $235.95
19172808 - Victory Red - $278.71
19172809 - Velocity Yellow - $278.71
19172810 - Machine Silver - $278.71
19172811 - Black - $278.71
19172812 - Jetstream Blue - $278.71
19172813 - Crystal Red - $278.71
19211166 - Cyber Gray - $278.71
19211165 - Switchblade Silver - $278.71
19211167 - Atomic Orange - $278.71
Stock Spoilers also available - Pricing as low as $144.86 - Please contact me for numbers/details
C6 Cargo Shade & Net
10321692 - Cargo Shade -$154.68
10321693 - Cargo Net - $43.77
Color Matched Body Side Molding Set
17802204 - Victory Red - $153.13
17802205 - LeMans Blue - $168.86
17802206 - Machine Silver - $153.13
17802207 - Black - $153.13
19166384 - Primer - $128.30
Color Matched Parking Brake Lever w/Boot
19158973 - Red - $98.22
17800668 - Cashmere - $98.22
17800669 - Gray - $98.22
17802416 - Titanium - $98.22
Body Color Interior Door Release Bezels
17803493 - Cobalt Red - $69.82
17803496 - Victory Red - $69.82
17803499 - Velocity Yellow - $69.82
19153792 - LeMans Blue - $69.82
Climate Control **** w/Chrome Ring
19129950 - $24.86
Genuine GM Console Lid with Jake Skull - 19209851 - $144.44
Genuine GM Accessory Console Lid with Logo
17802448 - Ebony With C6 - $99.30
17802449 - Cashmere With C6 - $99.30
17802450 - Cobalt Red With C6 - $99.30
17802451 - Titanium With C6 - $99.30
17802452 - Ebony With Z06 - $99.30
C6 Logo Floor Mats (08-up)
19172504 - Ebony With C6 Logo - $89.95
19172507 - Cashmere With C6 Logo - $89.95
19172511 - Ebony With Z06 Logo - $89.95
LS2 Color Keyed Fuel Rail Cover Set (left and right)
17800101 - Daytona Sunset Orange With Silver Lettering - $149.87
17800102 - Machine Silver With Red Letering - $149.87
17800103 - Victory Red With Silver Lettering - $149.87
17800104 - LeMans Blue With Red Lettering - $149.87
17800109 - Artic White With Red Lettering - $149.87
17800110 - Vlack With Red Lettering - $149.87
17800111 - Millennium Yellow With Red Lettering - $149.87
17800112 - Magnetic Red With Silver Lettering - $149.87
17802119 - Velocity Yellow With Red Lettering - $149.87
17802120 - Monterey Red With Silver Lettering - $149.87
19170525 - Atomic Orange With Silver Lettering - $149.87
Genuine GM Accessory Front End Bra
19202129 - With License Plate Opening - $89.73
19202139 - Without License Plate Opening - $89.73
Thanks!!!
Kevin
www.PartsTaxi.com
302-645-6221 x126
302-295-1240 - Fax
302-883-0227 - Parts Department Direct
kevin@lewesautomall.com
Old Nov 16, 2009 | 04:30 PM
0PartsTaxi.com
Former Vendor
Be sure to get in on these deals. We all have a long weekend comming up and could use a garage project to keep us busy
Kevin
www.PartsTaxi.com
