C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Which AFTERMARKET fuel rails fit the LSXr 102 intake with STOCK injectors?
Old 12-09-2009, 08:22 AM
bowtiguy
bowtiguy's Avatar
Default Which AFTERMARKET fuel rails fit the LSXr 102 intake with STOCK injectors?
I've searched and read almost every post on here in regards to LSXR intakes/injectors/fuel rails. I'm getting one painted with my valve covers of the Holidays and I want to make sure I have everything I need here to get the car running again upon my return.
I'm looking for an aftermarket fuel rail that fits the Fast 102 LSXR intake for the LS7 AND uses the stock LS7 shorty injector.
I know one member used the Nasty perf. LS3 rail and "modified" the mounting brackets.
another vendor said you could just put the mounting tabs of the FAST LS7 rails on a metal brake to shorten them to run the LS7 injectors etc..etc...
Any REAL WORLD experience out there? Please no speculation, just looking for answers w/o having to buy three sets fo rails hopeing to make one work.
Thanks!
Old 12-09-2009, 11:38 AM
bowtiguy
bowtiguy's Avatar
Default Update:
Fast says..yes this set-up will work
vendor "H" says...no! you have to run a spacer too, he thinks.
vendor "I" says LS3 option with spacer only OR larger injectors.
AAARRRRGGGGHHHH! I feel like Charlie Brown at this point.
Old 12-09-2009, 12:49 PM
ramairws6
ramairws6's Avatar
Trust me, don't listen to Fast cause they will lie to ya..........
Old 12-09-2009, 04:56 PM
IPS Motorsports
IPS Motorsports's Avatar
Its not that they lie, just some of their employes do not know all the products that well
Old 12-09-2009, 05:31 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
The problem with the intake is that it is not as stream line or flat on top like the ls7. Soooo, you need to make a junction between the lower injector and the now taller fuel rail. So, either spacers or injectors. I personally would use the spacers until I had to switch over to a larger one.
Old 12-09-2009, 06:06 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Correct. You can get away with using a spacer we just never do. The cars we put the LSXR intakes on always need injectors so we just do them at the same time.
Old 12-09-2009, 10:54 PM
Luweegy
Support Corvetteforum!
Luweegy's Avatar
Mike,just get a set of 60lb's injectors and be done with it.Then you can use your stock LS2 fuel rail.Get a set from Fran in above post.
Last edited by Luweegy; 12-10-2009 at 05:22 PM. Reason: My Mistake,Stand corrected.
Old 12-09-2009, 11:11 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
Originally Posted by Luweegy
Mike,just get a set of 60lb's injectors and be done with it.Then you can use your stock LS7 fuel rail.Get a set from Fran in above post.
You actually need an LS2 fuel rail and it will work.
Old 12-09-2009, 11:37 PM
bowtiguy
bowtiguy's Avatar
I'm thinking about it, just have to make sure Rod can HP tune the 60's.
Old 12-10-2009, 02:24 PM
IPS Motorsports
He should be able to assuming he has the flow data and latency tables, and a little basic math.
-Brandon
Old 12-10-2009, 02:33 PM
obzidian
obzidian's Avatar
St. Jude Donor '09
math? Argghhh!!!
Old 12-10-2009, 02:56 PM
SS MPSTR
SS MPSTR's Avatar
I used the FAST LS2 rails.
Old 01-15-2010, 11:39 AM
bowtiguy
bowtiguy's Avatar
Default They fit!!!
Like a glove.
set-up.
1) fast 102mm LSXR LS7 intake
2) stock GM LS7 injectors
3) Fast 102mm LS7 fuel rail kit FOR the 102mm LSXR LS7 intake
They even machined out clearance areas under rails that allow you to hide the coil harness plug UNDER the rails. With a -6AN vent lines coming out of my Katech coil relocation equiped valve covers, I thought things would be tight.
The complete opposite. I have MORE room now.
Old 01-15-2010, 12:14 PM
Randy@RaginRacin
Supporting Vendor
Randy@RaginRacin's Avatar
The Fast Fuel rails work great on the applications we have done.
Old 01-15-2010, 12:24 PM
BgBoost1
BgBoost1's Avatar
Like a glove.
set-up.
Mike, Engine looks great man....Congratulations!
Old 01-15-2010, 12:39 PM
rsmith1944
rsmith1944's Avatar
Does anyone have a suggested fuel line hook-up kit for the billet Fast fuel rails? Or a shopping list of fittings needed to make this up with A/N fittings and braided fuel line? What adapter to adapt too quick connects OEM fuel line? What vendor?
Old 01-17-2010, 09:11 PM
bowtiguy
bowtiguy's Avatar
I don't have the complete list, but from memory ( and my empty fast part box's)
1) fast fuel line adaptor P/N 54028
2) 180 degree -6an
2.5) -6an hose of your choice
3) -6an straight end
4) -6an to -8an 90 degree SWIVEL adaptor
5) fast LS7 fuel rail system (P/N 146027-kit)
6) -6an 60 degree ends (two to connect each rail)
7) -8an plug to cap it all off.
That pretty much covers it other than the line that matchs the ends you choose.
Hope that helps!!
BGBOOST1: thanks a bunch. a ton of bending over went into that project!
To Which AFTERMARKET fuel rails fit the LSXr 102 intake with STOCK injectors?
Old 02-21-2014, 01:18 PM
Phamz06
Phamz06's Avatar
Default hey I had a question relocating coil
Did you have to get new wires ? Did you get the msd universal wire set up ? What Bracket did you get ? And what cable covers ?
Old 02-21-2014, 03:50 PM
The Highlander
The Highlander's Avatar
This is great.... What I did.... LS1 kit and soldered the brackets to the top.... never an o-ring issue...
Old 02-21-2014, 03:54 PM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Keep a close eye on those rails. Seen more than 1 fire with people using those rails.
Quick Reply: [Z06] Which AFTERMARKET fuel rails fit the LSXr 102 intake with STOCK injectors?
