[Z06] Difference between T6060 and T56 transmission?
Hi guys, first post. Looking into buying a Z06 corvette, and researching difference between the model years.
Found out that the 2008's have a T6060 transmission that replaced the 2006/2007's T56 transmission.
My question is, what's the difference between these two transmissions?
Thanks guys!
Thanks guys!
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Don't know the mechanical differences but as I just bought an 06 Z last Saturday I have read that the 08 new tranny is 30 to 40 lbs heavier and some 08 Z owners notice some slight grinding noises when the tranny is not fully warmed up and they shift from first to second gear.
I am not sure why GM made the change but I am sure others will chime in here and know that answer to that!
Happy hunting!
Happy hunting!
Aside from the few problems that cropped up in the earlier released units of the 6060, as told to me by RPM Transmissons, the 6060 is the desired peice for high powered cars. I was advised to replace my T56 when I get my final forced induction build done as my T56 won't be able to handle the power.
With the updated trans, the shifting effort is better. There isn't so much knotchyness. From the page linked below: "The manual transmission shifting improvements include a more positive and direct feel during gear changes, with better gate-to-gate location. "
source:
http://www.corvettemuseum.com/specs/2008/index.shtml
Lots of details on this page here.
I do like the new trans shifting. However, both my '08's have/had shifting when cold problems. It will grind if I don't double clutch. Once warm, no problems.
The 2-3 shift at high RPM requires different finess(sp) than with the T56. So if your brain is programmed for the T56, you'll need a slight adjustment.
source:
ALL T56 and TR6060 transmissions can experience the 2nd gear cold grind thing. That behavior is not a new thing with the TR6060. I've seen a bunch of older T56 cars that did it and personally owned a couple.
I agree. It is a heavier duty unit in most aspects. It shifts more smoothly into all gears particularly reverse. The TR6060 will not fight you a little bit going into reverse like the T56. The throw of the shifter is also shorter on the 08+ models.
I think the TR6060 is rated at 500 lb/ft(at least in the Z06 and Zr1) where the T56 is rated at 428lb/ft capacity.
Ive had my '06Z since Aug. '06. I have well over 428 tq. My car is primarily a track car. although, it has now 34k miles combine with the old & new motor & also both track & street miles. Having been in the track a total of 42x (Ave. A total of4 hrs. Sesseions/day) on '06, & '07 combine. Slowed down a bit in '08 & '09 & track the car only 18x but that cuz I lost my motor & funds. Now '10, I've run 6x already. I hope I don't jinx myself but t56 continues to run strong. The only maintenance I do is replaced both tranny & rear end fluid once a year. I'll assume that the T6060 is a better tranny. But so has been the t56 for me & then some. BTW, my tranny is "TOTALLY STOCK"!
Main reason GM changed out transmission's is, the T-56 was fazed out when the 6060 came in. The 6060 may have improvements in some way's, but doubt you'll notice much of anything. Don't care much for the extra 40 lbs, though
JMHO- I don't think the TR6060 is as durable as the T56. I have a T56 that has been driven for the last 5yrs with 525+RWTQ being applied. No problems. From being on the forum there seemed to be alot of problems with TR6060. Maybe it got better, Who knows..........
I'm sure Borg-Warner changed hands........So not an option for Z06!!!
The T6060 was in my GT500 and i was very happy to know that it was in my 09 Z. The 6060s are more durable and can take more punishment. I was making over 800rwtq and pushing a 4000lb car with the Shelby. That much torque and weight is a huge strain on the drivetrain. The tranny never gave me a single problem for over 2 years. They are amazing pieces.
When we talk about production line transmissions. Cost does factor in. Or they would/could all be bullet proof. When GM switched to Tremac in F-body from Borg-Warner. They (Tremac) were junk. Not that Tremac makes a crappy trans. I don't think GM wanted to afford a better trans..........If that makes any sense..............
My buddy has thr tr6060 and has nothing but crap to say about it. Maybe he just got a ****ty one. Synchros gone bad twice in less then 15K. It happens.
I wonder how many guys actually had a genuine "problem" with the TR6060. The 2nd gear grind is not a transmission problem but rather a variant of normal operation while the transmission is warming up. The heavy duty synchronizers used require normal running temperatures to deliver peak performance. Aggressive operation of the shifter before the transmission has a chance to warm up can chew them up, but guys get frustrated and just jam the shifter into 2nd which is the last thing that should be done.
If the car is doing the 2nd gear grind/clunk when it's cold you have to just shift gently and let it do its thing. It will stop after a mile or two if nothing else is wrong with it.
